3PDT wiring w/ 9v
Started by DJPsychic, November 18, 2021, 06:04:33 AM
DJPsychic
Hello all,
I've never wired a 3PDT in this manner, so hoping someone can explain it or post a helpful layout.
On the "9V" lug, am I taking it directly from PCB?
antonis
You may take +9V from wherever you wish for but it should be more convenient to switch LED via GND ..
DJPsychic
Thank you Antonis.
If I take PCB 9v to switch like the diagram, do I still take PCB to DC jack?
antonis
Quote from: DJPsychic on November 18, 2021, 08:41:37 AM
But of course ..!!  :icon_wink:
PCB 9V comes from DC jack 9V in the way: DC jack -> PCB -> Switch -> 3k9 resistor -> LED (Anode ->  Cathode) -> GND
idy
What is that for? It refers to buffer out and fx out going to the same pin on the switch... need more info to understand.
Klon is a little different, has an odd grounding point in mid circuit to kill the distorted path or turn the LED on....
DJPsychic
