Klone Gain Pot wiring
Started by DJPsychic, November 18, 2021, 06:47:36 PM
DJPsychic
Using the layout below, is this the correct numbering of the gain pot?
https://www.sabrotone.com/klon-centaur-build-finished/
iainpunk
cheers
DJPsychic
DJPsychic
I should've added I'm asking because when I set gain at "0" it sounds a bit muffled and I lose transparency. Like turning the treble down.
From what I've read This is usually caused by wrong wiring but it appears I've got right  ???
iainpunk
might me the layout's mistake, or just a difference in numbering convention
give switching wires 4 and 6 a try.
cheers
cheers
DJPsychic
So reading the comments on the website of the layout, someone wrote
" I wired based on the 123 – top 456 – bottom with shaft up and lugs facing me."
And then
" Lug A1: Gain4
Lug A2: Gain5
Lug A3: Gain6
Lug B1: Gain3
Lug B2: Gain2
Lug B3: Gain1"
Sorry, I'm so confused  :o
Just want to make sure I get it right
