dead end fx oiolosse
Started by zach4728, January 18, 2022, 11:01:32 AM
zach4728
Im building a dead end fx oiolosse(clone of midnight amplification holy mountain). R3 calls for a 61k resistor. I'm wondering if this is supposed to be a 62k or possibly a 51k resistor. because 61k resistors are not available as far as i can see. Ive read another thread from june where another builder had issues in this same area of the circuit. if anyone has some input or advice it would be much appreciated. thanks
FiveseveN
In general 1.6% tolerance is negligible but is there a schematic that shows what this R3 is doing?
eh la bas ma
You can always solder two or three resistors together to get 61k. Like 47k + 3k3 + 10k for exemple.
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
zach4728
https://drive.google.com/file/d/1ddkG_90f9YdqizsWHmSlZKDCZyQZIlEX/view
there is a link to build doc and schematic. it doesnt look like they used two resistors in the photo of completed board but it could be hiding under the j201 board.
idy
It is unlikely that the value is critical. It is like what you call a "stopper", a series R on the Gate of the first JFET, but the 220k to ground makes it part of a voltage divider, a "pad" that drops the input level by about 1/4, maybe to keep it clean?
Weird input stage: No decoupling cap, just 1M pulldown, the "61k" series R, and then a 220k to ground to "bias" the JFET. No DC so no cap? No DC then why the "pulldown?"
GibsonGM
I would assume the 1M pulldown is for anything that is leaking in from something connected before the circuit (?)  I mean, it may be charging the 10p Miller capacitance, LOLOL.
This is just trying to be a triode gain stage.  Many tube amps have no input caps.  I would have used one to take advantage of the opportunity for some tone shaping, since it's not going to sound quite like a real triode anyway!
digi2t
We just present them like we find them. Spaceman is another one of those gonzo values examples.
Use whatever is closest.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
