please help with over voltage protection?
Started by iainpunk, February 02, 2022, 11:18:52 AM
iainpunk
so i have an overdrive design which requires a very specific IC and this IC will blow up if the supply voltage exceeds 16v.
that would not be a problem at all if only 9v power supply's were in use, but i see more and more people using 18v supplies.
i have a few 12v zeners, but regulating down with a resistor and still being able to deliver the needed current when on 9v, dictates that the resistor has to dissipate quite a lot of power to cope.
i'd rather not use a ''crowbar'' type protection circuit, and also, low parts count is appreciated, as i dont want to double the amount of components
is this just a risk builders take, or is it common to include some voltage protection?
How much current is needed for particular IC..??
iainpunk
Quote from: antonis on February 02, 2022, 11:28:03 AM
the circuit pulls about 35mA form the 9.6v supply
iainpunk
i feel like a slight idiot for not thinking of this simple circuit:
i can probably get away with using a 2n2222a, a 1k and a 12v zener
niektb
So you don't mind the standard voltage drop when running it on 9V? (not sure what kind of chip it is and what it needs)
iainpunk
Ow, its a bipolar/CMOS hybrid chip, (not a 4000 series).
I had one die on me when i fed it 17.5 volt.
It works / sounds alright down to 7 volt, so a bit of loss in the power supply doesn't keep me awake at night, haha
Cheers
niektb
In that case you could also throw in a standard LDO haha for improved noise filtering and regulation etc haha ::)
composition4
TLC2272?
Anyway here's my scheme I'm using on a pedal I hope to go commercial with... Next to no voltage drop, voltage limits itself at around 13v, no-harm reverse polarity protection... Might work for you, might be overkill
Jonathan
composition4
Come on, there's at least 20 words in his original post. Am I really supposed to read everything before making an ill-informed suggestion?
iainpunk
Quote from: composition4 on February 03, 2022, 08:21:23 AM
Yes you should, hahaha.
Im hesitant about adding 3 parts, let alone 8.
Still appreciate the effort tho. That regulation scheme has 8 components, thats more than half of the amount of components i have in this overdrive. Haha
Cheers
toneman
check out the LM317 adjustable regulator.
comes in TO220 case for heatsinking.
also comes in TO92 (transistor)type small case.
add 2 resistors to set the limits. done. 3parts.
probable a couple of caps at in and out would be good too.
RAMS or BENGALS?
8)
TONE to the BONE says:  If youTHINK you got a GOOD deal:  you DID!
Quote from: iainpunk on February 02, 2022, 03:39:07 PM
Cheers
all the larffink in this thread is keeping me awake at night.
" I will say no more "
iainpunk
Does the LM317 let through current if its supplied with less than it regulates to? Like if i were to set it to 14v and i fed the circuit only 9 volt, does the lm317 still supply whats left to the circuit?
Quotelarffink
what's that?
QuoteRAMS or BENGALS?
Am i missing something?
Cheers
Quote from: iainpunk on February 04, 2022, 09:41:20 AM
Quotelarffink
what's that?
Cheers
larffink = laughing
RAMS or BENGALS = an american sporting endeavour
