Troubleshooting a buzzing Rat.
Started by eh la bas ma, February 14, 2022, 10:09:49 AM
eh la bas ma
Hello,
I am trying to help a friend with his Rat build.
https://www.musikding.de/docs/musikding/rat/RatV2_schalt.pdf
There is a signal in bypass, but with a buzzing noise in the background (almost as loud as the signal). When the circuit is engaged, I can't hear the signal, just the buzzing noise, even louder.
We had some trouble with a difficult soldering iron, The old solder was really hard to re-flow, I am concerned that the board might have been damaged by heat.
My friend's soldering skills were a bit rusty, so I did my best to re-do some suspicious soldering joints here and there.
here are some pics :
[ Edit : pictures deleted, they were unecessary and the problem is solved ]
I am having a hard time getting rid of the buzz, I am not even sure that the board is still ok...What do you think ?
Any help would be welcome !
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
eh la bas ma
Oh... and of course, here are some voltage readings :
DC jack+ = 9.44V
VB (measured on R9) = 2.5 V
OP07
1= 9.04 V
2= 4.57 V
3= 4.09 V
4= 0
5= oscillates between 0 to 2.5mV
6= 4.56 V
7= 9.14 V
8= 9.04 V
2N5458
G= 2.5 V
S= 3.1 V
D= 9.13 V
Edit: I notice that i can't have proper readings unless the circuit is engaged, otherwise the meter keeps oscillating, both on OP07 and on the transistor...this can't be a good sign, but i don't know for sure.
GibsonGM
Check ALL grounds; the buzz really sounds like a bad/missing gnd.  Cold solder perhaps.  No gnd on output jack, things like that.  Check for continuity on every gnd.
Are you using a regulated supply to test the pedal?  Does it do this with a battery only?
eh la bas ma
Quote from: GibsonGM on February 14, 2022, 10:35:20 AM
Thanks ! I'll check every ground, install a battery, and test the circuit with it, and report.
I am using a Truetone 1spot.
GibsonGM
I'd imagine it would be pretty noise free then (unless something is wrong, but other pedals would show same issue).   Probably a ground, just like unplugging something and leaving the cord on the floor - bzzzzz!
Some don't use a 'wire ground' to the output jack and depend on the enclosure to ground it - if it comes loose (or is unboxed) there is no ground. Just one place to check.
eh la bas ma
#5
All clear, thanks for the help !
It was really an easy fix...Wires color was inverted on the footswitch's jack OUT : blue is GND, black is tip. I was confused by the colors and wired the tip to the GND... To think that I was almost doubting the board, along with my friend's skills...I should be ashamed.
Everything is fine now, I am even considering some clever mods : my friend intents to use his Rat with keyboards and synths...All your suggestions are welcome !
rule number one: meter your jacks and footswitch before you first apply power.
" I will say no more "
