Relay Choice Replacement
Started by sarakisof, March 03, 2022, 07:36:09 AM
sarakisof
Hello everyone, i have to replace some relays in a Fostex reel to reel tape machine.
Relay is the "Omron G2E 182P H 24V" old open type with plastic glass cover.
Today's replacement seems to be the "Omron 182P M 24V" closed type.
https://datasheet.octopart.com/G2E-182P-M-US-DC24-Omron-datasheet-18423033.pdf
As i cannot find it easily in EU, only overseas available or overpriced, i thought to find a cheap common 24V one and build a small extension PCB connect board so the pins can fit.
Are there any special specs (Amps, kinds of relays maybe) i should care? I'm really noob when it comes to relays.
Could you suggest a cheap easy to find one?
antonis
sarakisof
#2
Thank you antonis, pretty happy there are many -found also some others from Rayex Elevtronics- with same pinout scheme. I though i had to make a dedicated protoboard to make the pins fit the original layout, as the only 24V ones i found locally had a different schematic datasheet ..
Peaceee  8)
