question about increasing volume of Pedalpcb Mantle Fuzz
Started by snow123, March 27, 2022, 10:56:39 PM
snow123
hey, I recently built a PedalPcb Mantle Fuzz and found it to be too quiet (even when the volume is maxed, its still a little bit below unity), and I found it to not have as much gain as I would like, and after doing some probing I realized that before R16 and R17 (like while probing lugs 1 and 3 on the blend pot), the fuzz/octave effect has some more gain, and is much louder. so I'm thinking that lowering the value of R16 and R17 should fix the issue, would that be correct?
snow123
Quote from: snow123 on March 27, 2022, 11:57:15 PM
Paul was posting the schematic, which you neglected to include.  Not much we can do without it.  "R16 and R17" is meaningless, as is a layout.
snow123
Quote from: bluebunny on March 28, 2022, 04:15:33 AM
Ooooh, ok. I'm talking about R16 and R17 on the schematic.
antonis
Quote from: snow123 on March 27, 2022, 10:56:39 PM
Better try with 100k OUT pot
Gargantula
#7
R16 and R17 look like a voltage divider, so I don't think changing them would make any difference. I think Antonis is probably on the right track though, changing the value of the volume pot would probably help but I'm not sure how much. Replacing resistors on the board comes with the chance of burning off a pad though, so I wouldn't try anything like that until you get a definitive answer from someone who knows better than I do, but replacing a pot is easy enough.
There's heaps of gain and not much loss. I'm thinking assembly error.
What is the voltage across C7? Idle, and when playing?
idy
It is an MXR Blue Box, and there are threads complaining of low output on those. One mod is to remove/switch the final 10n cap, C9. Will also be brighter and rougher.
try searching blue box low output. Sometimes (maybe?)google search leads you to more threads here than the built in search.
snow123
Quote from: PRR on March 28, 2022, 12:21:55 PM
when idle, im only getting 0v to .2v, but occasionally ill get 2.5v to 3.2v.
edit: now (when idle) im getting anything in between 0.1v to 4.0v.
snow123
well the fuzz part of it just sounds dark and pretty low gain with not much definition.
snow123
Quote from: snow123 on March 28, 2022, 09:37:52 PM
and when playing, the positive side fluctuates in between 3.5v-5.2v.
and i dont get anything on the negative side since its grounded.
Vivek
Has the schematic mixed up the inverting and noninverting pins on IC 1.2 ?
Hope I read the schematic properly
snow123
Quote from: Vivek on March 31, 2022, 08:51:33 PM
nope, i just checked the tonepad schematic and its the same way.
Vivek
Oh, IC1.2 a comparator, not a linear gain stage !!
Which means it will swing from rail to rail even with a very small input signal.
That could lead to a lot of spurious signals !!
Are D1, D2 and near by components some kind of a noise gate ?
Quote from: Vivek on April 01, 2022, 02:57:28 PM
In a manner of speaking, yes.
I think that part is an envelope follower, generating a basic half-wave rectified envelope signal across C7. This envelope signal is then used as the collector voltage for the two transistors Q2 and Q3. Q2 is switched on and off at the input frequency. Q3 is switched on and off at a frequency two octaves lower, by the looks of it. So instead of getting a fixed voltage level switched on or off, we get an envelope signal switched on or off - e.g. we get some DYNAMICS!!! oooohhh!!
A side effect of this is that the envelope will hopefully die down to close to zero by the time that the fuzz and flip-flop tracking goes wayward, so we might lose that "splattery" decay that this type of pedal is prone to. And we also gate out any noise since the envelope will go down close to zero with no signal coming in, so even massive gain within the circuit shouldn't be noisy.
*I think*. I haven't analysed it closely, but that's my reading of it. Corrections welcomed.
iainpunk
well, IC1.2 is actually a Schmidt trigger, so its gating to begin with, although the threshold is quite low considering the gain stage in front of it. the threshold is about 0.044v above and below Vb
cheers
cheers
Quote from: iainpunk on April 03, 2022, 11:19:40 AM
Yes, that's true - there shouldn't be a bad noise problem.
There are two basic problems with this type of comparator-style fuzz though: You lose all the dynamics completely, even more than you would with high-gain fuzz, and you tend to get that spattery decay as the sound dies away and goes intermittantly above and below whatever threshold is involved. This modulating-the-square-waves-with-an-envelope method is a way of dealing with those two problems.
snow123
