Question about custom AB pedal for cab switching
Started by javadesigner, April 06, 2022, 05:16:53 PM
javadesigner
I'm looking for custom built AB pedal for cab switching (1 amp - 2 different cabs). Not amp switching, cab switching.
1 input jack (1/4") from amp, 2 output jacks (1/4") to cabs and a simple rotary switch to switch between the 2 output jacks. No LED required.
12 gauge wire internally (to match speaker cable) and a heavy duty rotary switch of "shorting" type - the switch leaves the current connection intact while switching to the new position, and then disconnects the current connect.
I was wondering if anyone on this forum can build something similar for me ?
Best,
-J
I suggest you go to a hi-fi shop (although not *too* hi-fi!) and buy a speaker switching unit. It's a simple device - a switch in abox, basically. It lets you choose one set of speakers or the other, or sometimes both. It'd work for a guitar speaker as well as any other, and you'd probaly only use half of it, since guitar speakers are generally mono, whereas hi-fi is generally stereo.
I assume make before break so the amplifier is never un-loaded?
Heavy duty rotaries are getting rare. Heavy-duty toggles are still around. IF your amp can stand a 2X load for a split second, this odd affair works.
javadesigner
Quote from: ElectricDruid on April 06, 2022, 06:46:10 PM
Hi - thanks for this suggestion! I looked around and saw some of these speaker switchers are meant for internally powered speakers and some are for unpowered ones. I would assume I would want the one for unpowered.
It might be simpler to just get a custom SPDT switch made with make/before/break. I'll reach out to some custom pedal makers on the 'net but does anyone here have any suggestions for custom builders with good reputations ?
Quote from: PRR on April 07, 2022, 12:11:57 AM
Yes, make before break so it is never un-loaded. I'll put the amp on standby before switching cabs just to be safe but momentary 2X loads are absolutely fine too.
GibsonGM
Could it be simpler and cheaper to just buy one?
I know Elliot has something on his site but it's probably more complicated than you need...
javadesigner
An update - found MBB (make before break) toggle switches at Kraus & Naimer and Carling Technologies.
These manufacturers don't have them easily searchable/findable on their websites but when I contacted their sales, both  were super responsive and helped me find a SPDT Toggle MBB switch with 10A rating. MBB switches + 10A rating was proving almost impossible to find, so I can highly recommend both of these companies.
