What to do with an extra op-amp?
Started by soggybag, April 22, 2022, 04:44:01 PM
soggybag
Here's a Rat like circuit cribbed from the 1981 Inventions DRV. The original uses a charge pump and runs on 18V. I figure with the diode clipping there isn't any use for a charge pump so I made my own version without.
If I use a TL074 there's only 14 pins but I end up with an extra op-amp. What to do with this?
- VRef buffer?
GGBB
Use it to provide your bias supply. Something along the lines of the following (specific values might vary):
antonis
You can use it to make a more "elegant" tone control" (e.g. Tubescreamer style..)
>off topic<
In cace you don't realy need the C2/R15 subsonic HPF (about 3Hz), you can omit both items and bias IC1_B directly from IC1_A output..
+1 what Antonis said. If you've got an extra op-amp, you've got an opportunity to make a more interesting active tone control. How about sticking a simple two-control active cut/boost on it? (Frequency and cut/boost?) Ok, it won't be an authentic "Rat-like thing" any more, but it might be more interesting, and it'd certainly be yours.
Fancy Lime
I would redesign it so that you can ommit IC1_A by including a second ground leg on IC1_B. You know, like the Rat does it. The TL07x series of opamps is plenty powerful enough for that and you can then use a TL072 dual instead of the harder to get quad. The frequency-gain structure will be slightly different (more like the Rat, obviously) but I doubt that the difference will be dramatic. Seems like your goal isn't to do an exact copy of the 1982 anyway, right?
Andy
mark2
You got some recommendations for productive things to do with it...
But in the event you truly have no use, here's a safe way to terminate it:  +input to a reference voltage, -input to output
antonis
On a second glance, there are some peculiar items values/combinations, like R7 (480R) and R12/R13 (10k/2M2)..
(not to mention almost all filters cut-off frequencies..) :icon_wink:
Vivek
Pre distortion mid control
Or
Blend for dry / rat mix
iainpunk
stick a wave folder stage in between the 2nd gain stage and the normal clipping.
it won't sound great, or even good, but it will be unique
cheers
cheers
Elijah-Baley
anotherjim
Clever.
When the signal is below the diode Vf it's unity-gain and non-inverting. If you feed both inputs of the opamp the same signal, the gain formula Av=(Rf/Rin)+1 doesn't work as usual. (Rf/Rin) cancels itself out leaving the +1.
When the signal is above Vf, its unity-gain inverting (the +input is "grounded" when a diode is on). So the output signal waveform gets folded upside down.
Of course, with a 9v single supply, the diode ground will be Vref 4.5v.
At least, that is how I think it works.
antonis
#11
It "folds" signal waveform..
It can be more easily understood if you replace diode pair with a "switching" resistor..
(OFF for signal amplitude less than 650mV - ON for more than 650mV..)
When OFF, output is unity (1 + 10k/10k - 10k/10k) and when ON output is 650mV*(1 + 10k/10k) - signal amplitude*(10k/10k)..
P.S.
Iain's circuit is intended for bi-polar supply.. :icon_wink:
edit: Jim is by far faster..!! :icon_mrgreen:
antonis
I have to disagree with Jim's second case interpretation.. :icon_wink:
Non-inverting input isn't grouned.. It's set on Vf.. Output is the sum of 2XVf + (-Vsignal)
In case of Vsignal isn't greater than 2XVf, output isn't folded upside down..
anotherjim
I put "grounded" in quotes. Be it 0v as in the schematic, or virtual ground of 4.5v.
soggybag
Thanks for all of the help. Here is what I did with all of this. I'll get around to the wave shaper at some point.
Extra op-amp buffers the bias supply:
Extra op-amp adds a tilt tone control. Not sure if I grafted that on correctly.
Extra op-amp adds Baxendall tone stack. Not sure if this is correct? I think this needs a bias voltage at the + of ID1_D (pin 12)
antonis
Bias supply is OK..
Baxandall configuration is also OK if pin 10 is connected to VR AND pin 12 too (via a 2M2 resistor, like you use for R3 & R20..)
Tlt tone control puzzles me a bit, so I've no comment.. :icon_wink:
antonis
Quote from: anotherjim on April 25, 2022, 04:04:05 AM
OK but I insist for 2 X Vr "crossover handicap" beyond an ideal signal folding.. :icon_wink:
(regardless of non-inverting input bias point..)
Quote from: soggybag on April 25, 2022, 10:55:04 AM
Yes, it does some bias, but you could just remove C8 and let it pick up the bias level from the previous op-amp stage.
In general, if you do that multiple times or with high gain stages, you finish up amplifying all the offsets up to a serious level, but in this case I doubt that would be a problem and the following cap C10 blocks any offset from making it to anything downstream anyway. So just put a wire link where C8 is and you're good for that one too.
The others all look fine, btw. Nice work.
antonis
Quote from: ElectricDruid on April 25, 2022, 05:18:43 PM
Is output stage of 1.0045 gain included in all the others..??
iainpunk
looks good
general advice from a sober version of me: don't take the ideas i post (under the influence of one to many) in threads too seriously. i build pedals that are weird and whacky one trick pony's, not pedals that have a broad range of applications.
cheers
cheers
