question about making a big muff with an jfet based input and output stage
Started by snow123, May 20, 2022, 03:48:24 PM
snow123
Hey guys, I'm trying to make a big muff with a JFET based input and output stage (and might replace the BJTs for JFETs in the clipping stage), but I'm not sure how to go about it.
I tried breadboarding just the input stage but with a 2n5457 instead of a 2n5088 (or any other BJT), and it didn't work (as i figured), and i only hear my picks attack when I try playing with it. so I'm wondering what I need to change to make it work.
here's the schematic I'm working with right now, but everything is likely gonna change, and I've only breadboarded the input stage.
Quote from: snow123 on May 20, 2022, 03:48:24 PM
Change JFET bias configuration.. :icon_wink:
There was a similar project from Jack Orman, but I can't recall it right now..
snow123
Quote from: antonis on May 20, 2022, 03:57:17 PM
how do i do that though?
Kevin Mitchell
Quote from: snow123 on May 20, 2022, 03:58:33 PM
May I ask the reason for altering Big Muff In & Out configurations..??
(or am I looking for land in trouble..??) :icon_redface:
snow123
Quote from: antonis on May 20, 2022, 04:08:29 PM
I'm thinking it would give it a different sound. and I just want to experiment with JFETs in a big muff, starting with the input and output stage.
Quote from: snow123 on May 20, 2022, 04:14:27 PM
May I assure you for the opposite..??  8)
P.S.
Be aware of oversights when copying schematics,,
(e.g. no ordinary BJT should work with that R20 value..)
AdamM
AMZ had the fet muff years ago... 4 jfet stages. It sounds great as I recall. Sadly I cannot find a schematic.
snow123
Quote from: antonis on May 20, 2022, 04:29:46 PM
P.S.
that was actually a typo lol, its supposed to be 100k.
snow123
so im assuming i change the value of R2 for it to work? 'cause i believe that resistor is what adjusts the bias for Q1.
Kevin Mitchell
Quote from: AdamM on May 20, 2022, 04:30:22 PM
I was curious about this one. Looks like it was pulled years ago.
But they did write a book that snow may very well enjoy! - probably why they pulled their schematics.
https://www.amazon.com/dp/B0749RW4Y6
Quote from: snow123 on May 20, 2022, 04:39:14 PM
For a BJT, yes.. :icon_wink:
Did you read the link posted by Kevin..??
If yes, we would be happy to answer any possible query originated from there..
Or you're just hoping for a ready-to-race JFET configuration scheme posted by some willing guy..??
anotherjim
JFET gates don't usually need a positive bias voltage - it can be hard enough to get the source voltage high enough to get it biased.
snow123
Quote from: antonis on May 20, 2022, 04:52:34 PM
yes, I did read the link. I guess I'm not entirely sure what JFET biasing circuit in the link would match up best with the input booster I have set up rn.
But my understanding of it so far, is that R4 and R5 would set the biasing, is that correct?
Quote from: snow123 on May 20, 2022, 05:04:55 PM
Not quite..
R4 in conjunction with R2 set channel current ID (current from +9V -> R5 -> Q1 -> R4 -> GND)
R2 serves to set a voltage level at Gate (usually near 0V)..
According to Drain desirable bias voltage and Drain resistor value (which sets stage's output impedance), there is a proper working current (ID = (9V - VD) / R5)
That current can be estimated by VGS /ID curve, so R4 value is set accordingly (VS = ID x R4) and VGS (absolute value) is VG - VS..
Gain of stage roughly is R5/R4 but by shunting R4 to GND via a cap you increase it to gm x R5..
Let's implement an hypothetical example..
R2 = 1M, R5 = 10k and ID = 450μA for a VGS = -1.75V
VG is 0V (due to practically no current flow through R2 - take it as I say it for the time being)..
For a VGS of -1.75V and ID of 450μA, we need a R4 of 3k9..
(of course, gain only approaches to 2.5 but a R4 by-pass cap might be proved your friend..)
Now you're ready to choose your particular JFET, read its datasheet and make your own Common Source amp.. :icon_wink:
P.S.
In case of weird results after exact implementation of the above said, put the blame on JFET parameters wide spread and not on me... :icon_redface:
snow123
Quote from: antonis on May 20, 2022, 05:57:59 PM
P.S.
Thank you!
Quote from: snow123 on May 20, 2022, 06:54:57 PM
Thank you!
You're welcome.. :icon_wink:
Just to confuse you a bit more:
It should be easier (IMHO) to implement self-biasing formulas, like ID = IDSS (1 - VGS/VP)2, where IDSS = Drain current for VGS = 0 (considered device almost maximun current) and VP = Pinch-off voltage (also found as VGS(OFF))..
Both the above parameters can be found on datasheets (exhibiting a wide spread, of cource..)
Then you can proceed to proper sizing of Drain (R5) & Source (R4) resistors values for VDS (Drain - Source voltage) and VGS (the one contributed in ID formula) via VDS = 9V - ID(R5 + R4) and VGS = VG - VS = 0V - IDR4..
Good luck..!! :icon_wink:
(a pot, wired as variable resistor, in place of R5 might be your good luck charm..)
anotherjim
If you don't like math, the trendy thing to do is fit a trimmer pot as the drain resistor. Usually, 100k is shown, but to me, 50k should give easier tweaking. Adjust for the best sound although the drain voltage should come out anywhere 3v - 6v.
The gate resistor to 0v basically only sets the input impedance. 1M is usually fitted for guitar input but these distortions often have lower about 100k which tends to make it more mid focused.
The output stage loads the 100k tone pot and that could have a 1M gate resistor but the original BJT is more like 100k I think.
m4268588
