DL4 No Power
Started by Corey5150, June 01, 2022, 12:51:35 AM
Corey5150
So, I just recently picked up a non functioning DL4 for ten bucks. I love to tinker on stuff, so I figured it may be a fun project. Seems to be a similar problem with these after extensive googling. And I've tried every suggestion pretty much mentioned.
I did not get a power supply, so we're running off 4 brand new batteries (I will be getting an adapter tomorrow though). I checked for cracked solder joints, couldn't find any, ran over some of them anyway. The diodes seem ok.
Now this is where I'm getting a little screwed up. This isn't the same board revision that uses the Max887/max660. This uses a RT7237, which has a different pin out. The voltage I get here shows 5.50 in, and 3.33 out - so, so far so good.
Then it goes down to another IC (which is supposed to be the doubler - the max660 in other revisions) and the input is showing 3.33, however the output on the pin is 1.22, it then Travels through to resistors to reach a voltage of 5.05. From my understanding I'm looking for a voltage of 6.6.
My thought process right now, is this chip needs to be replaced, but I'm not exactly sure especially with those resistors. And I can't find any info on what this IC is called. It looks to me like DL=1E followed by a 20Y below it.
Continuing with my tracing it leads to an S03A and 5.05 on pin 4 and 5, 2.5 on pin 6, -4.88 on pin 2, and -2.45.
Any help would be greatly appreciated :)
Sweetalk
Sometimes those voltage doublers have issues with the soldering. Remove it, clean the pcb really well and any residue of the old soldering and solder it again using solder paste or flux. Had the same issue in a couple and came back to life with that. If is not working, replace the IC. Maybe a good picture of it will help us to get the part you need.
Corey5150
#3
Yup! Its the old line6 DL4 - I managed to grab one of these and a Fulltone Full Drive 2 Mosfet for 10 bucks each. The FT was a fairly easy fix through tracing the signal. I knew the DL4 would be a bit of a challenge, but I was hoping it would be something simple LOL
I've attached two photos, one is the schematic of the power supply. (Not the correct revision though - can't seem to find it anywhere)
The second one is one I found on the Line6 forum - asking what the IC in question is called, he references different letters/number then I can see on mine. I'm going to try and get a picture - I'm just not sure it will focus on something that small.
As I've mentioned about the schematic, the U numbers are different so what I can see (the path it follows is VERY similar) and because of that U14 would be U23 (Max887 =U14, RT7237 = U23), and U20 would be U24 (Max660 = U20, ??? = U24) and obviously the pinnout is different as well. I also emailed Line6 support asking if they can identify the mystery IC.
EDIT: I attached a previous photo I took in the meantime, I'll try to get something a little more clear. (BUT if you zoom in, you can get an idea of what I saw [DL=1E20???])
antonis
Sorry but I'm confused a bit..
What are the voltages on IN & OUT of LM3480..??
Corey5150
Heres a much clearer picture, after some creative lighting
Corey5150
Quote from: antonis on June 01, 2022, 09:05:12 AM
There is no LM3480, it runs from the RT to the mystery chip to an S03A (LM2664). After looking at the data sheet... perhaps its meant to have a lower input voltage than 6.6v?
antonis
Theoretically, it inverts any input voltage in the range of 1.8V - 5.5V..
Without specific circuit implementation, I can't say anything more..
