Buffered output Wah oscillates - but not everywhere
Started by Lino22, October 14, 2022, 07:29:52 AM
Lino22
Antonis the pop is caused by oscillation, this is not the leaked DC pop.
My setup is guitar/or nothing > wah > amp.
When the core started to glow and people started yelling, he promptly ran out the door and up a nearby hill.
#21
Quote from: Lino22 on October 19, 2022, 09:41:08 AM
If so, it leads in oscillating buffer..
I'd try a BJT based buffer (don't worry about buffer's input impedance for the moment) of low output impedance..
(about 5mA working current should be OK..)
P.S.
I still can't see any obvious reason for using a buffer in the output of a Wah pedal but it should be "academically" interesting to find the cause of your issue..
Lino22
Yes, BJT was gonna be my next move, i will report back.
GibsonGM
I'd like to see the pop on a scope.  Or, can you make an audio clip of it?
anotherjim
The buffer is so the wah works with low impedance loads such as FF, but a 10k-15k in series with the output to the jack tip works well too if you don't mind a little level drop.
Lino22
#25
Quote from: GibsonGM on October 19, 2022, 10:21:44 AM
Good call, here you are. 1.33MHz, but amplitude modulated by something i can hear.
Probably I'm wrong but it seems to me like oscillation due to positive feedback via Gate to Source capacitance..
Could you try a 1k or so resistor in series with JFET Gate..??
anotherjim
That's what I was seeing. Where did you try adding a cap?
QuoteThat's what I was seeing. Where did you try adding a cap?
Also, look at the waveform when you have the added caps in place.
QuoteCould you try a 1k or so resistor in series with JFET Gate..??
And a 1k in series with the output lead.   Perhaps see if pulling the output jack,
which will remove any load capacitance, affects things.
I suspect the oscillations are there *before* be buffer.   However, you might
find placing a x1 CRO probe can stop the oscillation, so you need to do measurements
before the buffer with a x10 CRO probe.   A way around that might be to look
for oscillation on the output of Q2's emitter.
Phend
Mechanical fix:
Put in a stop so the pedal won't go down so far.
  • SUPPORTER+
GibsonGM
Quote from: Phend on October 19, 2022, 06:51:16 PM
Mechanical fix:
Or mess w/the R across the wah inductor to adjust the Q a little (trim pot?).  I'd like to HEAR the problem.  Every wah I've ever messed with needed something done with the "33k" across the inductor, to be honest.  Adjusts honkiness.
Lino22
#31
Mechanical fix:
... or maybe when the fellow starts quacking i'll say don't do it.  :D
Thank you guys, i am pretty sure the solution is at the door. I will have time to deal with it tomorrow, and report back.
Lino22
Quote from: anotherjim on October 19, 2022, 04:51:47 PM
I tried 47p between the wiper and ground as well as across the 10k emitter resistor.
Lino22
#33
Quote from: antonis on October 19, 2022, 04:28:42 PM
Yes, this may be it, i will definitely try it. Thank you. Or as Rob says one serial 1k at the output - it creates a low pass filter with the cable if i am not mistaken. And my coil cable audibly makes it less loud.
Lino22
