Wiring help
Started by spoontex, October 21, 2022, 09:06:25 AM
spoontex
Anybody can help me with this 1/4 jack wiring?
http://jhaible.com/legacy/subtle_chorus/sc_audio_balanced.pdf
I don't understand "Switch opens when 1/4" plug is inserted". I need mono or stereo jack connector? It's very confusing to me....
thanks.
there is a type of box jack comes with one or two isolated, sometines single throw but mostly double throw, switches, which are actuated by the jack plug. those can be used just like any panel switch, can switch any part of the circuit you like. the re-ann stye plastic jacks mostly have normally closed contacts, that is, shorting/closed when no jack plugged, which then open with insertion of plug, often catching the unwary. the open frame type metal jacks also can have normally closed switches included. you don't need or want a stereo jack necessarily.
" I will say no more "
Quote from: spoontex on October 21, 2022, 09:06:25 AM
The "Input 1" jack is a standard "switched" jack like in your link.
The "Input 2" jack is NOT a common type. In Switchcraft it is "13E", "Mono, isolated break circuit"
https://www.amplifiedparts.com/products/14-jack-switchcraft-mono-isolated-break-circuit
Note Nylon button far right. When you put in a plug, this breaks the isolated contact at jack bottom (top of this schematic).
spoontex
Quote from: PRR on October 21, 2022, 02:13:17 PM
I don't want to contradict you, but inputs 1 and 2 are not the same? At last the schematic is the same...
antonis
Quote from: spoontex on October 21, 2022, 05:36:07 PM
No.. :icon_wink:
Input 2 Sleeve isn't connected to Interface ..
(although its Tip acts a switch for Input 1 Sleeve..)
spoontex
Quote from: antonis on October 21, 2022, 05:50:23 PM
No.. :icon_wink:
I see... I think that I got it.
Thanks.
Quote from: spoontex on October 21, 2022, 05:36:07 PM...I don't want to contradict you....
Input 1 jack switch is switched to ground. That is a standard configuration (is easy).
Input 2 jack switch is switched to the Input 1 switch, not to ground. That needs an extra lug and nylon bumper.
spoontex
Quote from: PRR on October 22, 2022, 03:11:57 PM
I try to draw into kicad to understand...
Like this?
spoontex
Quote from: spoontex on October 22, 2022, 05:14:14 PM
Like this?
This way better with the 113EPCX
spoontex
spoontex
Quote from: PRR on October 23, 2022, 08:14:28 PM
Like this?
Looks right to me.
I've noticed that the pin order is wrong.
http://jhaible.com/legacy/subtle_cho..._sch_dwg3a.pdf
http://jhaible.com/legacy/subtle_cho...ge_overlay.pdf
pin 1 is gnd. But I'm not sure about the other two.
original Roland SSD-320 schematic
https://www.synthxl.com/wp-content/u...rvice-note.pdf
Comparing the two schematics. The original Roland. XLR pin 3 goes to the jack tip. So, I think that the pins numbers on the Haible schematic are ok, seems that the pin distribution is wrong. What do you think?
About the jack connectors. I need they are isolated? to avoid chassis ground?
