fet Matching
Started by spoontex, December 29, 2022, 06:38:39 AM
Clint Eastwood
Quote from: FSFX on December 30, 2022, 07:48:21 AM
Quote from: Clint Eastwood on December 30, 2022, 05:50:56 AM
So if you measure the same Idss, you can bet they have very similar Vgsoff, indeed they will have the same curve.
That is not actually true. Well maybe it is OK to assume that as long as you qualify that statement by adding 'if they are the same type of JFET from the same manufacturer and the same production run'.
The relationship between Vgs(off) and Idss varies considerably depending on the geometry of the JFET and the doping of the semiconductor material.
The transfer characteristic for normal operation is defined by Vgs(off) and Idss which determine the two end points of the forward transfer conductance curve used for typical operation.
This curve can be derived from these two end-point parameters using the following equation:   Id = Idss(1-Vgs/Vgs(off))^2
Sorry for not being clear, yes I meant for a certain jfet type. BF245 jfets will allways have very similarly shaped curves, if not  they would not be BF245's.
Clint Eastwood
Quote from: spoontex on December 30, 2022, 08:49:32 AM
This is the seller:
https://www.ebay.es/itm/304157747953?var=603269161743
The fet matching circuit works with a genuine j201, so I absolute convinced that this bf245a are fake.
I hope I am wrong, but..  looking at the picture, I think the Fairchild 'F' looks suspicious. The horizontal part of the F is too long. Incredible it would be, you have one life on this earth and then you decide to fake jfets...
FSFX
#22
Quote from: Clint Eastwood on December 30, 2022, 12:29:27 PM
This is the seller:
The problem is that so many of these devices are no longer manufactured but there is still a demand for them by people like guitar pedal builders.
So that is why there is an incentive for fakers to sell all of this remarked rubbish. If people didn't want to buy things like TO-92 J201s and these other JFETs then there would be less fakes around.
It's time for pedal builders to start using modern alternatives to all of these obsolete devices.
If it doesn't look like this then it is not genuine Fairchild.
spoontex
Quote from: FSFX on December 30, 2022, 01:12:46 PM
This is the seller:
Very useful information!
Thanks.
