DOD 250 not working
Started by HunkFunkPedals, April 12, 2023, 11:13:51 PM
HunkFunkPedals
I need some other eyes on this build...there doesn't seem to be any reason this isn't working. Getting bypass.
I'm not sure but it seems to me like IN-OUT-PCB-3PDT switch grounds aren't connected to PS ground (which is only connected to both pots lug 1..) :icon_wink:
P.S.
Ignore the above in case of indicator LED glowing when effect is ON..
Govmnt_Lacky
Quote from: antonis on April 13, 2023, 06:21:56 AM
P.S.
+1
Run a wire from your Output jack shield to the DC jack ground  ;)
SO many project pedals, whether boxed up or not, end up not working because of "wrong" jack lugs being connected.
One can begin troubleshooting by measuring the voltage on the V+ pin of the op-amp.
HunkFunkPedals
LOL!!!
I knew I just needed so other eyes on it. I cant believe I didn't see that. Thank you so much!
:icon_redface: :icon_redface: :icon_redface:
Under normal circumstances, you shouldn't get any response 'cause "this isn't working" says nothing.. :icon_wink:
