Pot Mounting
Started by Phend, April 20, 2023, 09:31:29 AM
Phend
Hello:
Question, how are pots with no threads typically mounted, for instance, in a 1590BB box.
See pics, pot with threads, and pot with bushing (313-1410F-5K).
I figured out how to use the one with the threads !
Paul
  • SUPPORTER+
Do you know what you're doing?
theehman
They're mounted to the pcb and the shafts go through the chassis.  The pcb itself has to be secured another way, like with standoffs.
Ron Neely II
fx schematics and repairs
antonis
By soldering (or just fastening) the 2 side tabs into respective pad holes.. :icon_wink:
very close tolerance panel hole, so the bush doesn't wiggle. that's not much bush to work with [insert your own joke here].
" I will say no more "
