Whoctahell
Started by Sylvain Ramone, April 21, 2023, 09:34:23 PM
Sylvain Ramone
Changing R4 to lower values increases output (4,7k , 15k, 20k, etc)  but loses octave ranges, so i choose 56k
Have fun!!
dimensions :64 mm x 38mm
https://docdro.id/2hKJ6wv
from
https://docs.pedalpcb.com/project/DirtDauber-PedalPCB.pdf
yes, but, you have 4 unused invertors on the pcb. you MUST terminate the inputs of all 4. tie to ground, tie to supply, tie some high and some low, tie one to ground and then out to in to out to in to out to in if you like, but you must always correctly terminate all unused inputs on cmos IC's.
" I will say no more "
Fancy Lime
Quote from: duck_arse on April 22, 2023, 11:21:24 AM
Unless chaos is the point, maybe?
