What schematic/pcb program are we all using now?
Started by mth5044, May 01, 2023, 10:01:14 AM
mth5044
Hey all!
Returning from quite a long hiatus. Excited to be back and see many familiar names and faces.
I used to use Eagle with modified gaussmarkov's library and then eventually madbeans. It looks like Eagle has gone through some... interesting changes? Autodesk, fusion 360, needing a license - is it worth figuring all that out, or is there a better option for the 2023 DIYer?
Thank you!
FSFX
I use KiCAD 6.0 as do lots of other pedal builders. It is free and highly functional.
r080
I was working on a list last year:
https://www.diystompboxes.com/smfforum/index.php?topic=129068.msg1245602#msg1245602
It seems like KiCAD and Diptrace have the big positive over eagle that 3D modeling is available in a free version. I am new to PCB design, having done just a couple in Eagle. I am working to switch to Diptrace because of all of Eagle's stuff.
Rullywow has a library for Diptrace. Not sure what libraries there are for KiCAD.
Rob
FiveseveN
I finally switched to KiCAD 7 and it has some welcome additions. And the built-in libraries should cover you (they even include tubes!).
tommy.genes
Definitely KiCAD here, though I haven't upgraded to 7.0 yet.
As I've put it before: "free or not, if it was good enough for the Large Hadron Collider, it's good enough for me!"
(Just as background, CERN does substantially contribute to the KiCAD project, but I can't say for sure that they used it on the LHC.)
-- T. G. --
"A man works hard all week to keep his pants off all weekend." - Captain Eugene Harold "Armor Abs" Krabs
marcelomd
Kicad++
I use custom symbols and footprints, because I'm OCD, but other than that, works out of the box and has batteries included.
I still miss Altium, but less and less.
Kevin Mitchell
Kicad for PCBs. I moved from Eagle/autodesk and haven't turned back. Absolutely enjoy it.
Fusion 360 (free) for models and stuff. You don't need to pay for membership - you are allotted so many editable files before it caps out. When it caps just mark your old projects read only so you can start up a new one. Could always go back to make it editable again - provided you've made space for it within the allotment.
That's been my workaround.
My apartment looks like an imploded RadioShack.
mth5044
Amazing, thanks everyone! Looks like I'll be learning KiCAD!
Lino22
When the core started to glow and people started yelling, he promptly ran out the door and up a nearby hill.
