splitter blend, why the JFET?
Started by m_charles, June 08, 2023, 08:40:45 PM
QuoteThere's nothing in it really though, so it doesn't *matter*.
Once the resistors are small, that's about it.
m_charles
Quote from: ElectricDruid on June 11, 2023, 05:49:58 AM
Quote from: m_charles on June 11, 2023, 12:48:25 AM
Any luck viewing it?
Yep, it's working this morning!
I adjusted it a bit for you:
You could adjust it further by replacing the phase invertor op-amp with just a plain inverting op-amp, like Rob suggested, and then the switch just chooses the output from either the buffer or the inverted version to go to the blend pot. I don't know why exactly, but it does feel simpler than this way. There's nothing in it really though, so it doesn't *matter*.
this is awesome. can't wait to build this up and report back. Thanks for taking the time to help!
marcelomd
If you are using 2 opamps for the phase inverter, why not something like this?
