Where is the broken part
Started by Instalinu, June 11, 2023, 06:06:56 PM
Instalinu
This is the schematics of the barber electronics dirty bomb, very high gain op amp distortion, as far as I know.
Mine is broken. It doesn't sound nearly as loud and distorted plus has some sort of highcut flair. Sometimes when you push the sp3d switch in a certain direction it goes back to normal, but quickly messes up again. I've looked round the capacitors and couldn't see Seth wrong. I replaced the fs twice but the same problem remained. Can you please check the schematics to tell me where I might look or replace parts.
Ty
Welcome Instalinu!
Antonis is right, an audio probe is a good way to start. You'd then go through the various stages of the pedal and check that you've got a solid signal at each location. At some point, you'll get to a bit where it goes bad, and that gives us a good idea where the fault is.
Your comment about wobbling the footswitch a certain way sometimes makes it go back to working correctly makes it sound like there's nothing fundamentally wrong with it and it might just be a intermittent connection (which are often a right b!tch to find since they're invariably working when you're looking for them and then broken when you're not). I'd check the offboard wiring carefully to make sure all the connections are good. Grab each wire and give it a little tug and a wiggle.
For audio probe test points, you could try IC1 pin1, IC1 pin 14, Volume pot pin 3, and IC1 pin 8. But check the wiring first. I'm not convinced the problem is on the PCB.
how have you built this, pcb, vero, perf, point-to-point, cordwood, breadboard? I'm interested in how those points marked +4.5V connect, as there is no point in the supply section marked +4.5V.
^ this...
no power section included on schematic.
yes yes, antonis, that is a diagram of something. but, how do we know it applies in this case? hmmm? how?
We don't until OP (who is vanished..) comes and makes himself clear.. :icon_wink:
MrStab
#8
Barber are geniuses for ensuring that anyone trying to Google how to make their pedal will be investigated for terrorism.
I bet 20 pence it's a biasing issue.
Recovered guitar player.
Electronics manufacturer.
eh la bas ma
#9
Quote from: MrStab on June 13, 2023, 12:49:31 PM
geniuses (...) will be (...) for terrorism. I bet 20 pence (...).
Really ? At this point i'd like to mention that I am in no way related to diystompboxes, or diystompboxes members, and I don't know anything about the " big nasty bomb" that has been discussed.
Besides, Guyatone Hell Monster would be more powerful than any Barber Dirty Bomb, right ?
I notice however that Mr Stab is quite suspicious : We were all shocked when he found a cunning way to use the words "geniuses" and "terrorism" in the same sentence. I can swear on every Holy Bat42 Diodes that's all I know.
...and long live the Revolution the Republic.
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
Lol, this thread got out of hand even quicker than normal! :icon_lol:
GibsonGM
I'm not even gonna chime in...
MrStab
Everyone knows the real terror is in saying the word "barber" around a bunch of analogue electronics enthusiasts-come-guitarists!
for a laugh and to see if advert algorithms aimed at my search results really ,work
ive been searching for weapons grade plutonium online to see how quick my front door comes off its hinges... :icon_mrgreen:
Quote from: deadastronaut on June 14, 2023, 05:43:16 AM
and..??
GibsonGM
How do we know that it's now actually Rob posting to his account, and not MI6?
https://www.bunnings.com.au/products/building-hardware/door-hardware/door-hinges
for DA [the other]'s missus. altho, with her job, see must know of some good door repair people.
any thread left unattended by OP will degenerate into bomb talk quicker than you can say russian invasion.
door is still intact surprisingly.... :icon_mrgreen:
eh la bas ma
#18
Quote from: deadastronaut on June 18, 2023, 09:32:04 AM
Weapon grade plutonium is probably a common thing these days. I'm afraid that's not enough anymore. Don't they put some of it in the fields to kill the bugs ? Maybe also in toothpaste, to quickly get a very bright smile ?
If you'd like to trigger some sort of serious alert, you could also pay a quick visit to the closest police station, explain to them that they don't need to be concerned, you are just going to build many Barber Dirty Bombs, because it sounds great with lots of power on tap, and the world will be a better place after that. Even then you might have to wait a few days before things get in motion...
I don't think law enforcement officers will barge in your home, like in the movies. First they have to collect informations, see who is your leader, etc.
Justin, are you working on a manifesto? that would get you noticed, fer sher.
