Eqd tone job as preamp for 3118 module, volume control mods
Started by Locrian99, July 26, 2023, 02:07:03 AM
Locrian99
Hello,
I'm playing around with a 3118 module for a simple pedal board practice amp setup.   And have a strip board build of an eqd tone job laying around so I figured it would make a fine pre amp set up.
https://docs.pedalpcb.com/project/BoxAndAll-PedalPCB.pdf
I'm pretty happy with the tone, but I'd like the volume to be a bit more fine tunable and less at max.   I was running the 3118 with a 9V 2a supply through a 1x12 cab and had to to the barely turn it to get audible before it was beyond comfortable practice levels when the kiddos are sleeping.
Could I just lower the volume pot value to accomplish this.  Would there be any drawback to using a trim or picking a resistor value and then just adding a voltage divider style volume
Control before the power amp.
Use a 10k trimpot for R10..
FWIW, I'd use IC1.2 for VREF buffering..
QuoteUse a 10k trimpot for R10..
Maybe change R10 to a 15k fixed resistor and it's done.
Quote from: Rob Strand on July 26, 2023, 05:42:52 AM
Yeappp..
OP clearly said: LOWER..!!!  :icon_redface:
Locrian99
