Why not noiseless-bias BSIAB2 and Pinnacle style circuits?
Started by darron, August 03, 2023, 12:20:05 AM
darron
Hey all. Here's something I've wondered for years. The BSIAB2 and Wampler Pinnacle (and many similar) circuits use Mu amp circuit biased by a network of 1M+1M from V+ and ground. Here's a reference schematic for the BSIAB2 https://generalguitargadgets.com/pdf/ggg_bsiab2_sc.pdf
MY question is; can we use noiseless biasing with say a 10K+10K voltage divider connected by a 470K/510K resistor? Example of this here: http://www.geofex.com/Article_Folders/modmuamp/modmuamp.htm
I've seen reports of people building the circuit this way, but not successfully. Only in debugging threads.
I do this for clean boosts. But maybe there's a good reason NOT to do this for distortions? If Brian Wampler doesn't... Maybe the distorting transistor state affects the bias and then the clipping nature? Some magic like that?
Thought it would be better to just ask rather than design a new experimental board layout. Is this a design consideration, or an oversight? Thanks.
QuoteMY question is; can we use noiseless biasing with say a 10K+10K voltage divider connected by a 470K/510K resistor?
Absolutely fine doing that.  From the amps perspective it's identical - except lower resistor noise and some more current from the supply rail through the 2x10k's.
In many circuits the bias resistor is applied to the input of the circuit.  In the case of the mu-amp the bias resistor is applied after the gain stage, it's kind of a buffer.   There's also a 100nF or 1uF across the gate-source.   What I'm getting at here is the bias network probably contributes less noise for the mu-amp than some other circuits.    I haven't checked exactly how much but that's what it looks like to me.
Quote from: Rob Strand on August 03, 2023, 03:04:09 AM
IMHO, there is another important (frequently overlooked) factor, which is the divider filter cap..
In the abscence of that cap, power supply rejection is only 6dB (half of Vcc ripple) severely dominating stage's stability, especially when the amp must supply large currents into a load..
amz-fx
I should measure that. I believe that I have some proto boards that could be adapted for that purpose.
Best regards, Jack
darron
Thanks everyone. I have a little more confidence now, and will do a new board design with the filtered divider. If I don't report back here down the track then we'll assume it was a success :P
I'm planning to make the boards publicly available. It's on the long to-do list.
Still wondering why this isn't applied more often. It's not like it adds more parts or complexity where there are multiple stages.
GGBB
I did the noiseless bias thing on the BSIAB2/Pinnacle a number of years ago - works fine.
darron
Quote from: GGBB on August 04, 2023, 02:22:18 PM
Perfect! That's a really cool schematic, too. I haven't actually tried the Pinnacle or the Brownacle. Brownacle mods look interest, I should give that one a shot... So double thanks : )
Clint Eastwood
C15 surely doesn't have to be 100uF?   10uF would already give a roll-off frequency less than 1 Hz.
Gord, I'd move LED & respective circuit before R19.. :icon_wink:
P.S.
We continually argue about RLED1 & RLED2 values but this particucalar configuration of yours does credit to me.. :icon_biggrin:
GGBB
Quote from: antonis on August 05, 2023, 07:13:18 AM
P.S.
Old schematic - from before I knew better. :icon_redface:
MrStab
It's like a milky coffee if you keep the Nyquist noise of the original biasing: Brown Sound with a hint of white noise
Recovered guitar player.
Electronics manufacturer.
Quote from: Clint Eastwood on August 05, 2023, 04:54:15 AM
For frequency response, we want "small" cut at 20Hz or 82Hz.
For power crap filtering we want LARGE cut at 50/60/100/120Hz. As much as we can afford or fit.
100uFd against 23.5k is like 0.07Hz. Compared to 60Hz this is 857:1 attenuation. Volts of ripple come out milliVolts. In bulk the cost of 100uFd 10V is 10 cents or less, not a severe dent on profit.
Of course if the power is clean you do not need that much filtering. A 10uFd is pennies cheaper. If it buzzes in the customer's rig, blame his power supply.
In DIY I just use whatever medium big cap is handy.
darron
Thanks everybody. I did the noiseless bias method and it worked great.
Schematic here: https://www.dazatronyx.com/docs/Brown-Sound-schematic.pdf
If anybody wants to grab a PCB off me for the project hit me up. It's partially SMD populated, since the transistors are going to be SMD FETs anyway.
Don't mean to make it too much about advertising, but in the spirit of DIY, I also have the project files or a complete kit for sale on my site as a result of this conversation: https://www.dazatronyx.com/#brownsound
Did you intentionally place C9 in series with only R7 (and not before both R7 & C8)..??
GGBB
Quote from: darron on August 04, 2023, 07:13:30 PM
I still have a few Brownacle PCBs left over in case anyone is interested. PM me for more info.
printer2
So used to seeing the 470k/470p combination in series with a large pot. Would there be less noise if a follower were after the gain stages and scaled down part values were used, say scale the parts by a 10X? (47k/4.7n/50k)
Fred
darron
Quote from: antonis on August 21, 2023, 08:24:58 AM
Yes. I think that way makes a little more sense, and shouldn't have any change tone-wise. But I could be wrong. I've been building them like that for a while.
darron
Quote from: printer2 on August 21, 2023, 01:37:52 PM
That's a good point. I always wondered if the 470K heavy signal series loading was an important part of the distortion/interaction at the next stage. Same with the 500K gain pot. At least it will only add noise on the lower frequency shelf, not the upper one.
ZVEX Box of Rock has this same magic 470K/470p section.
Geofex has an article on modding the MU amp to be like a buffer, but without adding a third follower transistor. Just adding a 1K resistor: http://www.geofex.com/Article_Folders/modmuamp/modmuamp.htm
POTL
the input impedance and the internal capacitance of the amplification stage must be taken into account. Unlike operational amplifiers, discrete amplifiers can be dependent on these values. I will be a bore (haha) but once again I will speak out against the idea of ​​​​Mu Amp. This design is not as well filtered as single transistors, and wave clipping is not like the class A amplification of single transistors or triodes. My verdict, Mu Amp and Jfet should have retired a long time ago (especially since they are getting harder to buy). Instead of Mu Amp, it is better to use Baja-style OpAmp, it is more predictable and flexible. If you need the behavior of a triode, look to Mosfet, it is also more predictable and flexible.
printer2
Quotethe input impedance and the internal capacitance of the amplification stage must be taken into account. Unlike operational amplifiers, discrete amplifiers can be dependent on these values. I will be a bore (haha) but once again I will speak out against the idea of ​​​​Mu Amp. This design is not as well filtered as single transistors, and wave clipping is not like the class A amplification of single transistors or triodes. My verdict, Mu Amp and Jfet should have retired a long time ago (especially since they are getting harder to buy). Instead of Mu Amp, it is better to use Baja-style OpAmp, it is more predictable and flexible. If you need the behavior of a triode, look to Mosfet, it is also more predictable and flexible.
Irregardless of the type of amplification stage, is there any reason to use high impedance circuits that are lifted right out of a Marshall tube amp or would there be a noise advantage to scale the parts by (as an example) 10X?
Fred
