Transistor FET 2N3820 equivalent
Started by HeavyMetalfx, August 16, 2023, 06:50:53 AM
HeavyMetalfx
Does anyone know of a readily known equivalent for a Transistor FET 2N3820?
GibsonGM
If you post a schematic of what you're hoping to use the sub in, that would make it easier to find a suitable replacement. I have seen this discussion on other boards, and it seems they usually trim out the replacement to get it to act properly...new FETs are much better, basically.
HeavyMetalfx
Clint Eastwood
2N5460, 2N5461 or 2N5462 are all equivalent to 2N3820, but with different pinout. And with the 2N546x range they made three different groups according to Idss value.
They are all obsolete, and being  P-channel jfets, there are very few of those in production today, at least as through-hole device.
There still is the j17x series made by Onsemi, maybe the j176 would work in your circuit.
antonis
HeavyMetalfx
HeavyMetalfx
Quote from: HeavyMetalfx on August 16, 2023, 06:50:53 AM
Oh, the Fairchild datasheet is fairly open ended
https://pdf1.alldatasheet.com/datasheet-pdf/view/83029/FAIRCHILD/2N3820.html
Silconix suggest J270 as an equivalent:
Low-ish Vgs_off P-channel.  Idss fairly normal to high.
Good chance you will want an equivalent to that
I can read the schematic at all.  Can't even tell if it's a P-channel  :icon_eek:.
Chillums
Just throw up a link to the build doc your working from.
HeavyMetalfx
Keep clicking, this should open 19" 50cm wide.
These are switches. Switching gain/response in amplifier stages. The only critical spec is P-type JFET. Should be simple. But JFETs are dying, and P-types died first.
N-types would need a negative supply AND a lot of re-rigging.
You could replace with 4066 CMOS but keeping the polarities straight is too much for my mind.
