2 smd transistors and no labels. How do i know which is which ? [Solved]
Started by eh la bas ma, August 17, 2023, 09:41:27 PM
eh la bas ma
Hello,
I am building a  Fairfield Circuitry Shallow Water clone.
https://docs.pedalpcb.com/project/LowTide-PedalPCB.pdf
It's a full kit from musikding.
Unfortunately they didn't write the names of the 2 smd transistors.
One is a J201, the other is a 2SK208.
How do i figure it out ? Does it even matter in this circuit ?
I have other builds with J201 transistors. I thought maybe I could try one of the unknown smd transistor in one of them and see if it changes anything.
But i suspect 2SK208 should sound quite close to a J201...
Every suggestions are welcome !
Edit : Both are soldered on smd adaptor boards. I tried them at both locations.
All i can notice is that the boost (from the internal DPDT)  is louder with one of them.
Any idea which one would be louder ?
"One Cannot derogate, by particular conventions, from the Laws which relate to public Order and good Morals." Article 6 of the Civil Code.
"We must not confuse what we are and what society has made of us." Theodor W. Adorno.
idy
No schematic in the build doc. "Coming soon." Have a heart, pedalpcb. Can make a board and sell it but can't add a schematic.
QuoteOne is a J201, the other is a 2SK208.
From Build doc:
Q1 2SK208-Y JFET transistor, N-channel
Q4 J201 JFET transistor, N-channel
Don't need part names on the PCB just Q1 & Q4 positions on the layout.
If the problem is you can't identify the parts themselves.
smd J201 might have a marking of 62P on the top
2SK208-Y  might have a marking JY on the top
You could also measure VP using fig 10 circuit:
https://runoffgroove.com/fetzervalve.html
J201 will have a lower VP.
eh la bas ma
Quote from: Rob Strand on August 18, 2023, 02:37:03 AM
From Build doc:
You could also measure VP using fig 11 circuit:
Thanks a lot !
I managed to read 62P on one of them, with the help of my phone. Problem solved.
Glad i could avoid building some extra circuit, just to tell them apart...
Now, all i have to do is calibrate this thing, and it's going to be quite difficult.
