Rat with Dual Opamp – mind helping with the last section?
Started by T-Dub, September 12, 2023, 12:03:49 AM
T-Dub
Hello!
I'm mucking around with a circuit and would love some knowledge dropped on me.
I'm wanting to make a Dual Opamp Rat but the second stage is bugging me.
Here are my questions:
– Original Rat inverts the signal – is there a reason I shouldn't keep both IC's in a non-inverting state? I'm wanting to eventually wrap a clean blend around it so I assume I should keep both IC's the same
– Will I have enough output to just run the second ic as a buffer?
– If I don't, and want to add some gain, I'm getting confused when to send something to VR vs when to send something to ground.
– I'm also a bit confused as to when to add a VR reference at the input of the IC – some circuits use it (like a HoneyBee), and others don't (like a Timmy)
Here's my schematic
patricks
Hello!
I can help a bit, I've been breadboarding a Rat-related circuit and the forum members have been super helpful :)
Some answers below.
The original Rat doesn't invert the signal, it uses the non-inverting input to the op-amp. The inverting input also has the feedback network applied there, and the high pass RC filtering (https://www.electrosmash.com/proco-rat)
I don't think the buffer will mind much if it's being fed with a low output signal. If you want some gain from that stage (for recovery after clipping and the tone control) experiment with the value of R11
Vref would be applied at R9 rather than C14
The Timmy uses a Vref, applied to the inverting input: http://revolutiondeux.blogspot.com/2008/05/wanna-build-timmy-overdrive.html
T-Dub
Quote from: patricks on September 12, 2023, 12:47:40 AM
Hello!
Some answers below.
Oh awesome! You've pointed out some brainfarts, so thank you!
If I could borrow your eyeballs and brain a little longer....
This was how I was going to buffer...
and this was how I was going to add a bit of gain – I think I can send it to ground (instead of vref) because it's not on the input? Do I gain anything by sending it to ground to vs vref
patricks
Quote from: T-Dub on September 12, 2023, 01:26:49 AM
Hello!
Some answers below.
You're welcome! I've been helped out so much on the forum with many brain farts, I'm glad I can pay it forward :)
The buffer option looks good to me (but I'll defer to larger brains if I've missed anything).
The gain option looks good, too. My understanding is that you want to reference that feedback network to GND rather than Vref to keep it as "clean" as possible. Have a read through this thread where Antonis helped me puzzle through the very same thing, also with a Rat schematic I'm modifying (I'm up to the stage of having prototype PCBs in hand but haven't built it up yet. So close!)
GGBB
R8 and R10 are unnecessary. There's no harm in R8 except that it robs about 10% of your output. Without R10, POT1 (volume) can be smaller e.g. 10k (R10 and POT1 in parallel form a single resistor). You probably don't need to add gain to the output buffer, but if you do, R11 and R12 should be bigger like 100k and should go to ground through C15 which should be ~220n. If the plan is to tame high end with C13, it does very little because gain is only 2. But making it significantly larger e.g. 10-100n will reduce most other frequencies as well (not dramatically because gain is low). As you raise the gain of this stage, C13 will have a bigger effect and will have less effect on lower frequencies.
antonis
Quote from: GGBB on September 12, 2023, 04:55:51 AM
It could be of somewhat lower value (down to 100R say) for oscillation prevention in case of shorted (or connected to a vely low impedance) outpout..
This looks fine to me.
No, you have to send it to Vref, but it's nothing to do with it "not being on the input". You have to think about the DC levels. Ignore the audio for a moment and just think about where the voltages sit.
The buffer is fine because its +ve input is fixed at Vref by R9/1M. The audio input and output are capacitively coupled, so no DC from them can interfere. So the op-amp sits happily at a mid-point voltage waiting for audio to come along.
The stage with gain has the same input, so that's good and sets a DC level. The output will therefore go to that same level. However, the foot of the feedback network is at ground, so there's a DC potential (of about 1/4 of the supply) being fed back to the -ve input by the divider R11/R12. That puts the -ve input at a different potential to the +ve input, and op-amps hate that! They *always* try to have their inputs at the same level. If you take the bottom of the divider to Vref, there's no DC potential across it and the problem goes away.
However, there is another better solution which you already have on your schematic, which is to add a cap at the bottom of the feedback divider (like C6 or C7 on the first stage). No DC can cross the cap, so the divider becomes AC-only and will provide feedback for audio but not affect the DC level. Another way of stating this same thing is to say that the cap forms a highpass filter and the gain rolls off to zero at DC.
antonis
Quote from: ElectricDruid on September 12, 2023, 10:05:39 AM
You could just tell that there is also DC gain (1+R11/R13), Tom.. :icon_wink:
Sorry, didn't read the following.. :icon_redface:
antonis
Not really... :icon_wink:
2nd op-amp is directly DC biased at Vref by 1st stage output (no DC blocking cap..)
3k3 resistor Vref connection is another cap saver common minor(*) design flaw..
(*) In an ideal world, ideal op-amps shouldn't mind at all but in a real world op-amps suffer both from input bias currents (especially bi-polar ones) and input offset voltages..
patricks
Ah, cool, thank you :)
For the OP this is another great point for reading up on, RG had a good article at Geofex about op amp biasing and making sure differential voltages at the inputs don't get too wide
T-Dub
Wow, honestly I am chuffed.
I now have my underlying confusion cleared up around vref vs ground, and how the cap blocks the dc so therefore can go to ground.
Even got two examples with the two different implementations.
Thank you all so much
antonis
Quote from: 287m on September 12, 2023, 09:09:28 PM
Dylan159 did dual opamp RAT.
A decent design with IN-OUT in phase and no Vref connections puzzlement.. :icon_wink:
(with a minor objection about R6/R7 values..)
Elektrojänis
Quote from: antonis on September 12, 2023, 08:33:29 AM
Or preventing oscillation beacause of cable capacitance... It only aplies when volume pot is maxed though. When it's not the upper half of the vol pot will do the same.
If you want to prevent the oscillation with minimal "signal robbing", you can put the resistor between the pot wiper and output. 10% is under 1dB though, so it should not make much difference.
antonis
Quote from: Elektrojänis on September 14, 2023, 03:24:06 AM
In such a case, when Vol pot is turned all the way down (dead silent output) op-amp has to fight with DC blocking cap..
(it's not good to have a severely oscillating amp even if you don't hear anything, is it..??) :icon_wink:
For unknow or dynamic load, it should be better to place that resistor inside the NFB loop..
(with just feedback cap one leg rewiring..)
Elektrojänis
Quote from: antonis on September 14, 2023, 05:47:02 AM
I probably didn't express clearly enough what I meant, but maybe a Q&D mockup pic based on OP's design will explain. This is what I meant:
I dont see how turning the volume pot down would make the opamp fight with the output coupling cap. There will be full 100kOhm of the pot between the output cap and ground.
That one probably goes beyond my understanding, but to me it seems like placing the resistor inside the feedback loop partially cancels what I wanted to do. I wanted to separate the cable capacitance connected to the output of the pedal from the output of the opamp and the feedback arrangement. The cable capacitance (you could think of it as CL in that image) could actually stop the feedback for high frequencies as it will form a low pass filter with RX. CF should mitigate that if it's big enough though.
Anyway.. .I don't really see a need for keeping output impedance under 1kOhm when we are talking about guitar pedals. Using 100kOhm volume pot on the output will make the output impedance higher anyway if it's not turned up to max.
antonis
Quote from: Elektrojänis on September 15, 2023, 03:19:21 AM
My bad, then.. :icon_redface:
(mistakenly imagined configuration..)
T-Dub
OK gang, think I've got my head around it - does this clean blend make sense?
T-Dub
...and one more question – will a simple low pass on the clean work/be enough?
antonis
It makes sense but only for Vol pot FCW setting.. :icon_wink:
For Vol & Blend pots setting at 50% say, you don't have Dry-Wet "equal" mixing..
Better move Vol pot in place of R14 (make it 100k or so), make Blend pot 10k(*) and add 1k or so series resistors on both IC1.A & IC2.B outputs..
(*) For more effective mixing, retain Blend pot 100k value..
