Sanity check on a simple hard clipping switch arrangement
Started by ctelecaster, September 30, 2023, 09:19:39 PM
ctelecaster
I'm 99% sure this is the dumbest question of the day, but these two arrangements of an ON/OFF/ON in relation to a pair of hard clipping diodes are functionally identical and both "correct", right? The objective is center disconnected, one side connected through a limiting resistor, and the other side connected directly.
idy
Even simpler is to permanently connect the resistor and just short it with one contact of an SPST switch
marcelomd
Quote from: Rob Strand on September 30, 2023, 10:02:44 PMEven simpler is to permanently connect the resistor and just short it with one contact of an SPST switch
Not the same. You lose the option of "no clipping".
Quote from: marcelomd on October 01, 2023, 12:26:50 AM
I was following the OP's schematic but his text says "ON/OFF/ON", so, not the same in that case.
stallik
With the above arrangement, you may notice a volume change between bypass and diodes. At least, this is what I found so, I wired a switch like this to overcome the issue
Vary the resistor value to suit the diodes
