simple active tone control
Started by Lino22, October 15, 2023, 01:45:42 AM
antonis
Quote from: Rob Strand on October 19, 2023, 11:55:06 PMThe 820k feedback resistor used or biasing probably screws up the behaviour of the Baxandall tone control a bit.
I'd say more than a bit.. :icon_wink:
A rough estimation of its apparent value [ 1 / (Q4/Q5 gain + 1), due to Miller effect ] tells me that it should be more wise for Q4 to be biased via a +15/0 V voltage divider..
Although there are designs with even lower biasing resistor value (like R12 below)..
https://keith-snook.info/wireless-world-articles/Wireless-World-1974/Baxandall%20tone%20control%20revisited%20DCD.pdf
Lino22
So the C11 cap raises the apparent value of TR2 collector resistor, by which it helps to raise the input Z of the TR2 stage for the bax signal no to bleed?
When the core started to glow and people started yelling, he promptly ran out the door and up a nearby hill.
antonis
No..  :icon_wink:
C11 raises R15 Value (not the total Collector resistance) for higher open-loop gain, hence more predictable closed-loop one..
(see what happens for an inverting configuration op-amp, disregarding the fact that Tr2 Base could hardly be considered virtual ground..)
Tr2 Zin raising indeed exists but should be considered negligible.. :icon_wink:
Quote from: antonis on October 20, 2023, 06:39:16 AMI'd say more than a bit..
Compare it to the ~~50k+10k of the audio path feedback network. 820k ~~ 10X 60k. Someone has cleverly held the nominal error down to about 1dB.
There is another error b/c the open-loop gain of one transistor is not infinite. Typically another part-dB at "flat" and several dB at "+20dB boost".
If you really care you will throw the 23 cents for TL072.
