Octavius PCB Guitar Mania level issues
Started by spoontex, December 09, 2023, 11:37:03 AM
spoontex
Hi,
I've just build the Octavius from PCB Guitar Mania:
https://pcbguitarmania.com/wp-content/uploads/2020/12/Octavius-Building-Docs.pdf
And I have a output level issue. With the switch at the octavia, the pedal works fine, but in the fuzz mode I have very low output level.
Any suggestion??
Thanks.
antonis
spoontex
Yes, but it's a PCB and I can't change the configuration. Do you think it's a design error?
antonis
#3
Quote from: spoontex on December 10, 2023, 02:16:55 AMDo you think it's a design error?
Not an error by its own..
(design principles are correct..)
I'd try to wire SW1 lug 3 on D2/D3/Vol-lug3 joint..
(not enough coffee yet, so proceed under your own risk..) :icon_biggrin:
