PCB mounting method
Started by stonerbox, May 31, 2024, 06:11:24 AM
marcelomd
Quote from: stonerbox on June 04, 2024, 12:12:29 PMI believe you have misunderstood the design, the pots are not inserted into the PCB. The pots are connecter with stranded wires, so no strain will ever be present at these connections.
Oooh, so you are mounting the pots to the enclosure and hanging the PCB off one (more?) pots via the strap+screw? Yeah. This was not clear from the pictures. You said "use your imagination", after all...
I thought that, in the final product, the metal strap would just lay along the enclosure surface.
Sounds 100% overkill =)
Also, if the strap is similar to the ones we have here, a blow to the enclosure could bend the strap.
I'd just do what Boss does. That, or epoxy glue the screw/plastic mount to the enclosure.
stonerbox
#21
Several pots, and no blow to the enclosure will ever bend these straps.
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
