Would Millennium Bypass work with a wah?
Started by Lino22, June 18, 2024, 09:46:38 AM
Lino22
Hi guys, would Millennium Bypass work with a standard VOX wah pedal?
When the core started to glow and people started yelling, he promptly ran out the door and up a nearby hill.
" I will say no more "
merlinb
Yes if you can fit a DPDT footswitch in place of the SPDT fitted to some classic wahs.
Lino22
I asked because there is stuff going on at the wah's output and i am not sure how much the output impedance changes with the pedal position. Hopefully it is in the MB range all the time.
merlinb
Should be fine, you can always add a pull-down resistor to ensure it works.
