Tonepad Small Stone / Pieditra with actual ca3094 vs ca3080
Started by Racase, June 18, 2024, 12:58:06 PM
Racase
Would I need to modify the circuit if I were to include the original ca3094 vs the Tonepad layout calling for ca3080s ics?  I have bought some I think they're the cool audio...  Anyway, what modifications would be required?  I see there's many more transistors in the Tonepad layout.
idy
the 3094 has a darlington pair buffer built in, the other chips need one added. Tone pad is laid out for the 3080s with added darlington transistors buffers. GGG has a layout for 3094s.
Kevin Mitchell
I've built the GGG version with CA3094. Worked fine.
This page is a gem for fine-tuning a small stone - particularly regarding the bypass volume drop.
https://generalguitargadgets.com/wp-content/uploads/smallvlp.txt
Racase
Could I just bridge each Darlington pair?  I already own the Tonepad PCB.
idy
It looks like you could. Carefully compare the two schematics. I would maybe try one stage at a time just to prove the concept before you get too deep.
Kevin Mitchell
#5
Quote from: Racase on June 18, 2024, 05:19:42 PMCould I just bridge each Darlington pair?  I already own the Tonepad PCB.
Omit the transistor pairs Q3&Q4, Q5&Q6, Q7&Q8, Q9&Q10, Q13&Q14, as well as all of the 2K and 47K resistors.
Bridge the base (pad 2) of the first transistor to the emitter (pad 1) of the following.
That should do it.
Racase
Bridge base to emmiters instead of emitter to base as in the schematic?  For only those ommitted?
Here's what I have, I bridged all the 2k and 47k and all the pins of the transistors that we ommitted:
Kevin Mitchell
#7
I'm not quite sure what you did there. But it's not right.
Inside of the CA3094 the 2K, 47K and transistor pairs are all included - so you should not populate their places on the board.
For the "bridging", the point is to bypass (or jump over) the transistor footprints to complete the signal routing. I suggest using the empty transistor pads rather than wiring from one component to another since it would look cleaner.
Use wire jumpers rather than solder blobs.
Kevin Mitchell
#8
Red X means remove the resistor (10 resistors) Edit: technically you don't need to remove them since one lead is not connected to anything - so they're not doing anything but taking up space.
Blue lines are jumpers (5 jumpers)
Definitely clean up your solder work. Let us know how it goes.
Racase
Finished today.  My Piedrita pedal build Works great and I recommend it :) .  I tore three traces so I made some connections with resistor leads.  I'm going to experiment with different transistors too since I've got sockets.  Thank you everyone. :icon_biggrin:
Kevin Mitchell
#11
Nice, good job!
Edit:
Though in your photo it looks like you were off a pin on the Q9 jumper. Fixing that will recover the 4th phase stage.
