Have you ever put the LM324 to use this way?
Started by Mark Hammer, June 20, 2024, 05:15:56 PM
In his Stompbox Cookbook, Nicholas Boscorelli uses the LM324 quad op-amp to use in an unusual way, that he describes below.
Here's the circuit.
 A very counterintuitive use of the chip, and approach to distortion.  Have any of you used it in this manner or built the Distort-o-Matic IV or simply tried one somebody else built?  I'm curious about what it does or doesn't add.
Never tried it, but it sounds like a good way to add plenty of hiss. At least the signal is boosted before it goes through, so there's some management of S/N.
StephenGiles
Yes I breadboarded this 2 leaking heart valves ago, and the hiss sounded great through an Electric Mistress!!
Quote from: StephenGiles on June 21, 2024, 07:11:44 AMYes I breadboarded this 2 leaking heart valves ago, and the hiss sounded great through an Electric Mistress!!
Fortunately, containing hiss is easier, less costly, and less painful, than containing heart-valve leakage! There are many points of potential intervention in this multi-op-amp circuit to trim cumulative hiss with feedback-loop caps.  Of course, almost any flanger will make hiss sound fascinating.  (Stay well, Stephen.  I'm hoping to get back out your way, maybe next year.)
StephenGiles
