Op amp issues
Started by Jaymucas, September 06, 2024, 03:16:48 PM
input to any voltage within the spec sheet spec. hence, not ground [unless dual supplies], not V+ [usually - both these nots are easy to remember, hard to get wrong].
" I will say no more "
Quote from: Matthew Sanford on September 09, 2024, 10:58:04 AMAh... so input to bias voltage on an unused op amp?
On a single supply, definitely yes. On a dual supply you'd use ground, but on a dual supply ground would be in the middle like our bias is here. Like Duck says, you *could* use any legal input, but it's not worth doing something special just for that so we re-use bias/ground.
OP - ignore this! Sorry for the hijack.
antonis
Shouldn't we wait for OP to define the use of single or dual op-amp..??
Quote from: antonis on September 09, 2024, 11:27:58 AMShouldn't we wait for OP to define the use of single or dual op-amp..??
We're just chatting amongst ourselves while we wait for them to come back with a schematic, Antonis... :icon_biggrin:
