Voltage issue with PH1 phaser build
Started by shattered, November 21, 2024, 09:55:42 AM
shattered
Hello!
I'm building a PH1 phaser from the original schematic. After assembling the circuit (except the transistors and opamps) I've checked voltages and noticed that VA and VB are practically the same (~0.1V difference).
Is this how it should work or maybe there's some error in my circuit? PH1r has a similar power section and voltages look OK. The PH1r has a .1µF capacitor from VC to Ground, I tried that in this circuit without success.
Here's my schematic:
Any input is much appreciated.
antonis
VB should be 5.1V..
Check D3 connection to GND..
shattered
D3 is correctly installed. If I don't find the solution I'll install a new one and check again.
Thank you!
shattered
It was the diode. I suspect that I damaged it while bending the pins (I didn't have the pliers on hand).
Thanks so much!
