Radio Shack PCB kit!
Started by Hal, October 23, 2003, 06:15:18 PM
Hal
Everything you need -- two 3x4-1/2" copper-clad circuit boards, resist-ink pen to create circuit patterns, etching and stripping solutions, etching tank, 1/16" drill bit, polishing pad and complete instructions !!
For only $15 !!
Now, while I haven't made a PCB yet, I think this is the biggest ripoff ever.  the boards should be $2 each.  They sell just the echant for $4.  The "poslishing pad" is probably just a sponge.  I have a drill bit.  And I don't need a "tank," I can use a bowl or whatever.  The marker is a $1 sharpie.  So my final question is, what is "stripping solution?"  What is it used for?
BillyJ
I think that is the rubbing alcahol they give you to remove the etch resist ink...I mean sharpie ink.
It is the biggest rippoff. I know from experience.
The drill bit is kinda big too....never used it!
A burn nd a half!
Buy some PNP blue instead!!!!
Hal
haha yea, thanks.
I think I'm going for tonar transfer on my first try, though.  Wish me luck!  (don't worry, I probably wont actually start the project in about a month...)
What do you guys use as a "tank" (bowl) ?
The Tone God
Quote from: HalWhat do you guys use as a "tank" (bowl) ?
A plastic storage container from a one dollar store.
Andrew
Mike Nichting
I use the casserole bowl that my ex left. I really dig the little blue folwers on the side of it.
Allt he best,
mike N.
"It's not pollution thats hurting the earth, it's the impurities in the water and air that are doing it".
Quoted from a Vice President Al Gore speech
smallbearelec
Hal--
Check out the photo-essay at Tonepad on how to use P'N'P blue. The process is consistent once you know the right setting for your iron, but getting to that point may take a try or two. Yes, a Sharpie (buy the Permanent type) marker from the hardware store is useful for touch-ups and filling in the occasional void. Denatured alcohol or acetone (also from the hardware store) will work as a solvent for the ink, and for many other jobs. Yes, avoid the RS kit, but the etchant is good and not impossibly expensive. If you need wire number drills (#59 and smaller), I have them. I will have more of the finer numbers on the new stock list that's coming out in January. A Scotch-brite pad and some Bon-Ami (supermarket) will be needed for preparing the copper surface of the board.
