Tonepad PCB's
Started by petemoore, November 14, 2003, 01:17:08 PM
I have a PDF challenged question: if you order a PCB from Tonepad does it come with the [what's it called 'layout'?] showing where connections are to be made on the board?
 I'm planning to do a Small Clone build [And Small Stone when the board becomes available] and would need the 'layout' showing hookups and board, or at least the schematic, I used to be able to see these at Tonepad but I've somehow recently become PDF challenged I guess...
 Also Jfet matching challenged question...do either of these require matched Jfets?
