eBay lot 2 stock list is up, get it quick!
Started by ExpAnonColin, November 14, 2003, 06:44:10 PM
ExpAnonColin
http://experimentalistsanonymous.com/ebaylots/lot2.html
I HAVE A LOT OF STUFF HERE!  I PLAN TO RE-EBAY MANY OF THE RESISTORS UNLESS SOMEONE WANTS HUGE QUANTITIES.  SOME OF THE PARTS WILL NOT BE USEFUL TO US EITHER, SO I'LL  HAVE TO RE-EBAY THEM TOO.  BUT GET WHILE YOU CAN WHILE IT'S CHEAP!
RESISTORS:
I have many many resistors of various values below... Resistors are 1c apeice or much cheaper if you want to buy a lot of them.
3.92 ohm, 1% tolerance (be creative, get a bunch of these and put them in series to create many many values) (5000)
22 ohm, 5% tolerance (5000)
36 ohm, 5% tolerance (5000)
130k, 5% Tolerance (3000)
560kohm, 5% tolerance, (5000)
2 megohm, 5% tolerance (4000)
Again, if you would like a large quantity of these before I re-put them on ebay, let me know.
I also have packages of the following:
1 megohm, packages of 25, 1$ per package (Carbon comp, I think, 10% tolerance)
Package of 2 3-watt resistors at 2.2k - anyone building an amp? 5% tolerance, 25c/package
Capaticators:
A few hundred - Tantalum (I believe) caps that say "725" on them... however, I doubt that they are 7,200,000pf capacitators.  If anyone can help me ID these, it'd be appreciated.  I'll sell these for very cheap if you want any.
A few hundred - See above, except these say 929 on them.
A few hundred - One more lot of tantalums, these say 224M on them.
A few hundred - Nonelectrolytes, I think 56pf.  These go for really cheap too.
A few hundred - Mini, black, radial mount nonelectros @ .01uf, 50v .  Cheap.
1 - MWR 100V 22uf non(?)electrolyte, 10% tolerance - $1
380 - Small, yellow, nonelectrolytes, more .01uf's.  V rating unknown.  Cheap, just ask.
14 - Sprague, "powerlytic" 200V 1200UG cap.  25c each.  Good for amps.
Approx. 2000 - Electrolytic (?) capacitors at 10uf.  Sold in packs of 100 for $3 each.
Many hundred - 10uf tantalum, black radial mount.  2c each. LEDs, etc.
13 - somewhat large, rectangle shaped LEDs with plasic enclosures.  50c each.
Transistors
I have a few various transistors, none of which would be useful for DIY audio purposes.
ICs
100 or so X2444PTs.  In static cases.  If anyone really needs these, I'll let them go for very cheap.
100 or so MC2060Ls.  In static cases.  If anyone really needs these, I'll let them go for very cheap.
50 or so - 745158's.  If anyone really needs them, they're cheap.
5 - 9606 DOU7F Z308 .  Again, very cheap.
Many 100 - White and blue ICs, various values in the 7-8k range.  Cheap.
11 - MC934F.  Flash memory, I think.  In individual cases.
75 9313EK NEC P/N UPD65664GD-013-SBD - In dry package, antistatic individually packed... high tech stuff.
Cases full of ICs.  Little boxes, individual cells.  I have about 5 different boxes.  10$ each with ICs, 7 without.
Wire/Cable
45 18% cables... like the ones they use on TV antennas, you know?  10c each.  Maybe use it for an EXP pedal?
100 or more - 5 wire ribbon cables, grey, bendable, about 6" - 5c each.
50 or so - 14 PIN Rainbow cables with DIP sockets on either end, maybe 2 feet or so.  10c each.'
Sockets, etc.
107 or so - Sockets for 7 pin or so rainbow cables. 2c each. 8 - 25 pin DIP sockets.  Square-style.  5c each. A bunch of odd things for suspending your PCB or something...  I'd try drilling holes in the bottom, sticking these in there, then putting your PCB on the other side... although they are a bit tall, at around 1 ".  1c each.
Tubing - Protect your wires.  Little 1 cm black tubes.  3000 of them, 1c each, much less if you buy a lot.
9 PIN Computer cable connectors.  Female.  This'd be nice for external boxes that require more than 2 conductors.
That's about all there is worth trying to sell..  sort of an odd lot here.  I'll be re-ebaying a fair amount of it, but get what you can use while it's still incredibly cheap.
Please send all inquiries to colin@experimentalistsanonymous.com.
I will be doing 2 shipments - one in exactly one week, and one once I get payment from those of us who don't use paypal (probably about a month).  Then I'll re ebay it all.  So get payment to me by next Friday, and I'll send it then, otherwise you're going to have to wait a while... sorry, it's just that making so many trips to the post office is a really really big pain.
Thanks for participating!
-Colin
