Fuzzy Tone in Tremolo
Started by Oliver, November 21, 2003, 06:49:27 AM
Oliver
Hi,
i build a KayTremolo (with DepthMod) from www.generalguitargadgets.com.
The Tremolo works fine, but when used with a Humbuckerguitar (SG),
the Tremolo sounds like a Fuzz, when hidding the Strings.
Is there anything i can change to get a clear Tone out of it?
Thanx for Your suggestions !!!
Oliver
Only dead Fishes go with the flow... >-))))-°>
jimmy
sounds like it has too much gain. to fix this you'd have to put a small value resistor from the gain stage transistor emitter to ground. i think maybe 470 ohms should do it but check with someone who knows what theyre doing first
good luck
Jim
"Who the f*** are the naked chefs?" - Ozzy Osbourne
tubes or bust
uncle boko
The very first effect I built was a tremelo from Practical Electronics back in the early 1970s. This too made a noise like fuzz - never managed to fix it!
better to be in bad taste than to taste bad
