Whipped up a '70 Fuzz PCB....
Started by Bucksears, November 29, 2003, 06:23:32 PM
Bucksears
and I'd like someone to check it out. Would anyone be willing to QA this PCB for errors? I'm not sure on the pinout of the transistors, but that part would be easy to correct. I just want to make sure I haven't overlooked anything.
Let me know who wants to give it a go!!
b_rogers
id love to look at it...did you do a drawing or a real pcb?
homegrown, family raised couch potatoes. temperament unsurpassed.
http://electricladystaffs.com/
Bucksears
It's a real PCB. I have been doing them in Adobe Illustrator for a while now. I made the grid size so 1square = 1hole on a perf board, then made standard (grouped) pads for a resistor, a small cap, a transistor socket, etc.
That way, it's just a matter of arranging them. I'll usually work from a previous PCB when making up a new one, then save it under the new name; that way I get to 'steal' the pads and rename the parts!!  8)
I can send it as a JPG if you'd like. It was done so it will print out ACTUAL SIZE.
Bucksears
Oh, I just need e-mail addresses to send them to.
Bucksears
Sorry, when I meant a real PCB, I mean it's not a hand-drawing or anything. It's a ready-to-print image with a parts layout beside it.
b_rogers
fenderbluesman63@yahoo.com
have you messed with the eagle layout program? i am trying to figure it out as we speak. JPEG would be great! Thanks man..
Craig V
I'd love to see it.
chiblues86 at aol dot com
Bucksears
Craig V
I got it.  Thanks.
I'm checking it over as I type this.  I'll go over it a few times, but so far so good.  I hope to build one real soon.
Thanks again.
Bucksears
I guess my main concerns are the transistors (since I haven't fully checked the pinout) and the trimmer. If anyone finds any errors, let me know and I'll change the layout accordingly.
Thanks,
Bucksears
OK. I checked the pinout at NTE for the C828 equivalent (NTE199) and the pinout is E C B, left to right, face up. I'll change the PCB either tonight or tomorrow with this update.
Bucksears
Craig and B,
Check your e-mail again. I went ahead and updated the corrections for the transistor pinout and sent you the updated jpg.
Thanks,
b_rogers
it looks right to me...i guess with the other layout you could use standard pinout trannies. exellent work bucksears. very intelligent layout.
Bucksears
Thanks! Now if I can only work out this Ibanez Super Metal SM-9.....
Davefx
I'd love to see it, too!!! :)
davefx@bellsouth.net
Dave
Bucksears
Dave,
Check your mail. As I've mentioned above, I'm pretty sure the layout is right, but I could be overlooking something.
Thanks,
Buck
Stef
I sent a PM- I'd love to take a look as well- thanks! :D
stefan.petras@earthlink.net
Stef
Stefan
Marcus Dahl
I'd love to see it as well.
homebrewelectronics@hotmail.com
You will probably want to use a NTE289A instead. It has the same pinout as the 199. I've found in most, not all, FF the 199 on the input side picks up radio stations. I use to use a combination of the 2 in my Beer Buzz. I still do fhrom time to time, but when the tone isn't getting it for me. I'll try any combo of things to get it. The 289A's wont do the radio thing and have the same pinout.
Marcus Dahl
Bucksears
Marcus Dahl
It looks good to me. Thanks for the layout.
Marcus Dahl
