Odie builders?
Started by brett, December 01, 2003, 10:12:30 PM
brett
I built an Odie from runoffgroove.com, and I reckon it's an excellent pedal.  Very nice overdrive sound.  I made 3changes to the original - a 4.7uF cap instead of 2.2uF in the first gain stage, for a little more "oomph", a 500k drive pot instead of the 250k, to allow for lower drive levels, and an adjustable low pass filter for a treble control (the one from the "Simple mods" page - a 10k pot in series with a .022uF cap).
Seems strange that I've never seen the Odie discussed in the forum.
Does anybody else like it?  Who has modified it?
Brett Robinson
Gary
You've just modded it!   :wink:
Rock on, brother!  Glad you like it.
RJB510
In the process of building it now (literally tonight). I'll let you all know what I think once its done (started late).
All I can say is that i've got high expectations based on what people are saying about it.
So its gonna be interesting, i'm sure i'll like it. Then i'll start on modifying it once its broken in a little :icon_twisted:
I build stuff. Guitar parts. Cars.
My Datsun 510 Build: http://ozdat.com/forum/viewtopic.php?f=33&t=17898
biggy boy
Quote from: brett on December 01, 2003, 10:12:30 PM
I have not buit this one, was going to.
Is it more of an over drive, then a distortion?
I was under the impresion it was a distortin circuit.
I was hoping to use it for heavy metal!
Glen
Renegadrian
I built a simplified version with no tone control - I liked it but well it's not my favourite one...Good circuit anyway...
Another great circuit from the fellas at ROG...
Barcode80
Quote from: biggy boy on May 21, 2009, 10:58:26 AM
Glen
to be clear, although some people use the terms distortion and overdrive and fuzz to describe varying degrees of saturation, they are all the same basic effect. an overdrive is a distortion...
biggy boy
Quote from: Barcode80 on May 21, 2009, 11:36:46 AM
I have not built this one, was going to.
I was under the impression it was a distortion circuit.
Glen
Man now I'm really confused :icon_eek: :icon_biggrin:
I've been playing for two year, and have only owned or used two pedals prior to making my own just recently.
A Digitech Grunge Which I think is metal and a wah. So far I just play in the basement to backing tracks. :icon_redface: :icon_rolleyes:
I have effects on my amp Vox Valvetronic but of course they don't say overdrive, fuzz or distortion.
I now know what a fuzz sounds like after building two of them..... and know what overdrive is from making a Valvecaster and a Gus boost to push my amp.
I just don't know what circuits here are good for heavy metal. Do you use a fuzz face or a big muff for metal? How about a Voodoo Labs overdrive with an extra clipping stage is that for metal? I just haven't had the exposure to different pedals in the past.
Glen
Barcode80
you can get pretty thick on the muff, you might try a dr. boogie (fet emulation of the sound of a mesa boogie) or the brown sound in a box (evh-ish). They can get pretty "metal" like.
biggy boy
Quote from: Barcode80 on May 21, 2009, 01:35:08 PM
Another member of this forum was kind enough to suggest the Brown Sound in a box also!
I was also thinking of maybe Mark Hammers CHAOS METAL??    http://hammer.ampage.org/files/Chaos.gif
Glen
Barcode80
yeah, almost any of mark's designs can get deep into metal territory.
aziltz
i just build an ODIE on the breadboard.  GREAT low gain sound, i love it!  now, what's more fun, perfboard, vero or etching a PCB?
biggy boy
For me I like etching my own boards wether they be ones I've down loaded from here, or ones that I have drawn up in Eagle.
I like PCBs for several reasons:
-They look cool and the process of making one is cool.
-I'm less likely to make a mistake and miss wire up components, because the wiring is already on the board. I just have to drop the components in.
  As long as I draw (copy someones schematic) correctly in Eagle then my board is guarantied to be correctly wired up.
- With perfboard, I find it too easy to get wires in the wrong place, missing connections......
