Ring Frobnicator Testing...
Started by petemoore, December 06, 2003, 06:15:10 PM
Is this ckt like wire up and go?
 OK I tried it once.
 Is the schematic confirmed to work...anyone try it?
RickL
I built it some time ago. It works exactly as advertised.
brett
A few of us have had problems with getting the low frequency oscillator moving.  A "flat-ish" battery or supplying the LFO with about 8V helped in my case.  Otherwise, it works, but don't expect a totally quiet effect when you're done.  There's plenty of "bleed through" of the modulation frequency.
Brett Robinson
Zero the hero
At high frequency I heard the carrier only... No modulation at all.
