Midi controlled audio gate
Started by Neutral, December 07, 2003, 10:53:00 AM
Neutral
Does any one here know of the existence of a Midi controlled audio gate?
Meaning a box that turns an audio signal on or off (various volumes would be even better) that is contolled by midi.
I want one :D
Rodgre
Didn't the SPX 90 do that?
Roger
Neutral
Interesting, It probably does, I'll check that out
Paul Perry (Frostwave)
It's often possible to pick up 'unfashionable' MIDI sound modules cheap (FB01 etc). Runing the output to a simple envelope detector & then on to a LED/LDR combo (like the detector part of a compressor) gives you the start of a simple MIDI volume control (or a MIDI wah, or whatever!). I only put this foward because, people might have the bits lying around, and if you like hacking, it would be an easy mod.
Also, ther eare plenty of MIDI lighting controllers that output multiple 0-10v control signals, and these can easily drive simple voltage controled amplifiers.
I'm not a programmer, so I'm always keen to use someone else's sweat!
jplaudio
Quote from: NeutralDoes any one here know of the existence of a Midi controlled audio gate?
I want one :D
Nobels MV-C $149
two channels does pan/balance/fade and accepts an expression pedal
analogguru
william
Although not specificly designed for this purpose, the midibox can be used for this purpose.  After building the core modual you can attach a dout modual to run LED's.  Using an optoisolater you can then use the midibox to gate a signal.  A buffer before the optoisolater and a buffer afterwards and you should have a pretty decent gate.  Information on building the mdibox can be found here.  http://www.ucapps.de/index.html.  I haven't actually constructed the gate portion yet, but it should work in theory.
William
