Dave Barber is a sick man...
Started by Rodgre, December 15, 2003, 11:57:55 AM
Lurco
Quote from: smoguzbenjamin on December 15, 2003, 12:13:59 PM
Hmmm, if anyone finds a nice combination, please post it up here!  8)
32xNE5532 ?
bt2513
What is this, exactly?  The musictoyz link is broken..
newfish
Tried this in the simplest of Op-Amp OD pedals.
Circuit is as follows...
TL071 Op-Amp
Input through 0.04uF cap with 5K6 resistor in series to pin 2.
Vref (2 x 33K voltage divider) to pin 3.
Ground pin 4.
9v to pin 7.
1Meg pot feedback from pin 6 to pin 2.
Output from pin 6 through .1uF cap.
Usual suspects of Si diodes between output and ground.
This is my 'polite' overdrive.
Just tried piggy-backing a 741 with the TL071 - and it really takes off - without being 'muddy'.
I can see some intricate soldering coming up...
Happiness is a warm etchant bath.
BoxOfSnoo
Quote from: bt2513 on September 22, 2010, 08:30:34 AM
It's all about stacking 2 opamps on top of each other so they run in parallel.  Check out the screamer lab project to see another way it can be done - though I think the bent pins are unnecessary unless you just want to switch them in and out of the circuit.
My Dropbox referral link - bonus 250MB of space for both of us if you use it
newfish
Quote from: BoxOfSnoo on September 22, 2010, 08:39:00 AM
It really is as simple as that.  It's like 'LEGO' with Op-Amps.  Check your datasheets to see if the two Op-Amps share the same pin-outs, make sure you stack the top chip the right way round, and try it.
With the pins of the top Op-Amp facing straight down, you should be able to 'clip' it on.  Makes for easy testing without needing to solder.
alparent
What if I used a quad op-amp instead of 2 stacked dual....what I get the same benefits?
Doesn't look as cool.......but I usually don't have my parts showing anyways!  :icon_rolleyes:
