Cheap, very low hz frequency counters?
Started by ExpAnonColin, December 17, 2003, 11:06:57 PM
ExpAnonColin
Just so I don't have to do the math so much... are they worth it, and does anyone know where I could get a 0hz-1mhz one, as opposed to 10hz-500mhz?
-Colin
There is a DIY project I've seen using one PIC and some seven segment displays to do a low frequency counter. I think the code is downloadable. Parts cost should be under $30
ExpAnonColin
Quote from: R.G.There is a DIY project I've seen using one PIC and some seven segment displays to do a low frequency counter. I think the code is downloadable. Parts cost should be under $30
Any clues to where itis?
-Colin
Paul Perry (Frostwave)
The key to a low frequency counter, is to use the signal you are examining, to turn on & off a counter that is counting a high freq oscillator.
Then you do some maths :)
That is why you don't see many very low freq counters (look for 'period' in the description if you wnat to find one)
Another bloody job for a PIC!
