Alpha stomp switches received
Started by ErikMiller, December 19, 2003, 08:19:41 AM
Jim Jones
BillyJ
They do have a nice footprint...Is there any talk about a 3pdt?
puretube
Quote from: BillyJThey do have a nice footprint...Is there any talk about a 3pdt?
and anybody knows of a "PCB-mount" version instead of solder-lugs ?
mattv
Mouser has the PCB mount version as well.
ErikMiller
Quote from: petemooreAnd the lighting on the Pic...Just thought I'd ad it derserves stellar comment...Really nice Deep Dopple :shock:
The surface behind the switches is my post form laminate kitchen countertop, which I Did Myself, in accordance with the philosophy of this forum. :mrgreen:
ExpAnonColin
When's the 3PDT version coming out?   8)
-Colin
dubs
So these are o.k for dunlop wah pedals? I heard the shaft length needs to be shorter so you don't switch the wah on/off when rockin the pedal... I'm looking for a dpdt for true bypassing the wah.
By the way mouser charging $23.95 for carling 316pp!!! That's robbery!
Fret Wire
QuoteSo these are o.k for dunlop wah pedals? I heard the shaft length needs to be shorter so you don't switch the wah on/off when rockin the pedal... I'm looking for a dpdt for true bypassing the wah.
Too long wouldn't be a problem. You'd adjust the height with the nut that sits right on top of the switch. The secound nut would tighten down from the top. Then you make small adjustments for whether you like to step hard or soft to actuate the switch. Too short would be a problem.
Fret Wire
(Keyser Soze)
