Again a mosfet boost question........
Started by Eddie, December 30, 2003, 05:55:41 PM
That thing started to piss me off too.
 I had to do another one for some reason and another worked out real good so far...the Volume knobs taper is quite compressed at one end...a little tricky to set...note, adjust vol, note, adjustvol, note, adjust Vol. max vol comes very quickly near the end of range, amd is waayyy tooo muchh for anything I have. Other than that it's one FINE Booster !!!
danelectro
yeh.. man i went to a shop today and had a guy play a SHO.. it sounded kinda the same but he wouldnt crank it up past half way 'cuz itd blow the amp' so i cant tell if the SHO distorted much or not..
this pedal i have here tho is pretty much unusable.. even at teh very lowest gain it distorts if you play the strings hard..
do you have to be carefull w/ pick attack, etc when using this thign? i wouldnt think so but if i play softly it works just fine..
