Chopper Fuzz Up
Started by Transmogrifox, January 09, 2004, 11:18:46 PM
Transmogrifox
Here it is.  I hope some of you find it pleasant.  The distortion itself is very pleasing.
Oh, one thing I forgot:   The diode on the JFET is a 1N4148 or 914 or so...however, other types may make the chopper less abrupt.
Here's the chopper specs:
Lowest Frequency:             .32 Hz
Pot Resistance
Position for 50 Hz
Chopper             :              318 ohm
*put a 320 ohm in series with the rate control to limit the
*high frequency range at 50 Hz
Pulse Width  With Rate Control at 50 k
Full 25k:         1.04 seconds
Down to 1k:    62.8 ms
for 1 ms PW, the equivalent resistance must be:
16 ohm, which is very near the resistance of the diode, so a full zero setting on the 25k pot will result in virtually white noise.  I haven't tried  this short of a pulse width yet, so I'm not sure what it sounds like.  The pulse width adjustment sounds best on lower frequencies, whereas the open switch on the duty cycle adjuster is best for higher chopper rates.
Comments are much appreciated...
Enjoy!
trans·mog·ri·fy
Transmogrifox
I'm great, aren't I?  I get through all this info and wordy stuff and forget the link.
Here it is:
http://www.geocities.com/transmogrifox/chopper.html
trans·mog·ri·fy
Interesting one !!!
  Fine work you've done here !!!
Marcos - Munky
Jason Stout
Thanks for the work!! I'll let you know if I try it!
Jason Stout
Transmogrifox
Hey Aron, Colin or Munky:
Are you guys willing to post the Chopper on your sites?  I would like to get some feedback about it to see if its worth my time to further pursue beyond personal use, either just the distortion alone, or the chopper concept...
thanx
TFOX
trans·mog·ri·fy
Jason Stout
I can give you some space on my site.
send me an email.
Jason Stout
Marcos - Munky
If you want, I can put it in my site too, or put a link to Jason's site. This will help a little for the people know your effect.
aron
Quote from: TransmogrifoxHey Aron, Colin or Munky:
thanx
TFOX
Of course!
aron
Here it is:
   Well here it is, the Chopper Fuzz.
Some things I did forget in the schematic:
1. An optional switch at the junction of the 560k and 120k resistors and the 47nF cap (connecting to the JFET gate)
This could be a 3-position SPDT switch where it's completely open in the central position (Chopper on), connected to Vcc in one position and ground in the other to select between fuzz and all-out Butt rock to Thrash Metal.
2.  The green boxed capacitor and 100k resistor has an error.  The 10 uF should be connected to ground instead of "V/2".   The 100k resistor should still remain connected to the "V/2" triangle.  This setup is based on a guess that some of the clock feed-through is coming into the signal path through the 1Meg resistors from "V/2".  Since no op-amp is ideal, I fear that the oscillator is taking a toll and chopping up the V/2 reference in a less than acceptable way.  The 10 uF capacitor to ground is intended to filter any wiggle in the V/2 reference so to supply a steady 4.5 V reference to the JFET switch.
Description of the Device:
The concept behind the circuit comes from a single coupling capacitor.  I found when using the .47 uF input coupling cap, the circuit produces a mushier BMP like fuzz sound.  When it is decreased to 10 nF, the circuit becomes a raging metalizer.
Now imagine having a metal distortion in series with a fuzz distortion (guitar--->>metal--->>Fuzz--->>Amp) on you FX chain.  Play along and stomp the fuzz on and off.  Now imagine a stompbox that does this automatically.  Now imagine this stompbox doing this anywhere from once every 3 seconds to 30+ times a second.  This is the Chopper Fuzz.
10 Hz to 30 Hz modulation time is when this effect gets weird.  It reminds me of Jimi Hendrix with a Univibe and another part of it like having a chorus on max rate and depth fed into a distortion pedal.  Professor, please please please don't make me derive the transfer function of this thing.  If the frequency response and feedback analysis isn't bad enough, combine that with square-pulse modulation and non-linear distortion...it could be a homework assignment from bad ol' Lucifer himself.
For those of you who are used to seeing an input buffer, you may think this circuit badly needs one.  However, this circuit is designed to use the volume pot in your guitar in the feedback loop of the MOSFET amplifier stage.  In simple terms, you can drastically change the amount of distortion just by rolling off the volume pot on the guitar.  When the volume is wide open, the impedance looking back into the guitar is smallish, minimizing feedback, thus approaching open-loop gain on the MOSFET stage.  When the volume pot is rolled back, the impedance looking into the guitar increases, which increases the feedback....gain goes down.
To say the least, the gain control is very nice.  It doesn't do nothing....do nothing...do nothing...then suddenly ramp up.  The distortion increases gradually with the gain pot.  On the low gain setting, hard-wired to the tight metal tone (coupling cap NOT bypassed), this produces a nice tight "crunch" hard rock distortion.  It makes me think of men with long hair and make-up.  I think they call that but rock. This device generates some wicked thrash metal tone when the gain is cranked up.  I hope all of you enjoy it...whoever builds it.
Ummm....if you post it on other pages, please leave credit to me...just to be courteous.  You would have to purposely remove the source from the picture to get rid of it, so you're already twisted if you repeat it somewhere.  It's nice to get credit when it takes 3-4 hours to draw up the schemeatic not to mention the 20+ hours of tinkering, calculating, and experimenting for taste....but that's the fun part.
transmogrifox@yahoo.com is a good place to send comments, suggestions, mods and other improvements...etc.
Arno van der Heijden
I'd like to hear this one... (hint, hint, hint  :D )
Transmogrifox
I'm still in much need of my own computer (I am a student and usually work out of university labs), and/or a friend with means of recording audio to post on the web.  I will most certainly post some sound clips of things on my site whenever I get a chance to record some....
trans·mog·ri·fy
Transmogrifox
QuoteI can give you some space on my site.
send me an email.
Hey Jason, what's your email ADR?
thanks a bunch...
Munky:  Do you want a JPEG in your email to post it, or just rip it off my site?
Aron: thanks
trans·mog·ri·fy
Jason Stout
Jason Stout
Marcos - Munky
Transmogrifox
Thanks again!  Jason, I'll email it to you tomorrow when I bring the CD that I saved it on...
trans·mog·ri·fy
ExpAnonColin
Quote from: Arno van der HeijdenI'd like to hear this one... (hint, hint, hint  :D )
+1 :)
-Colin
