Does size matter???
Started by 1wahfreak, January 15, 2004, 12:16:31 PM
1wahfreak
According to my wife, absolutely!!! According to electrons, I'm not so sure.
I mistakenly bought some ultra miniature electrolytic caps (mouser# 140-L25V10, 140-L25V100) for a tube screamer build. Does the physical size of a cap (or any componant for that fact) matter?. I'm assuming as long as the values are correct everything should be fine, but I just want to make sure before I solder everything in.
smoguzbenjamin
Make sure the values are fine. And that it can handle the voltages you're giving it ;)
Oliver
Quote from: 1wahfreakAccording to my wife, absolutely!!! According to electrons, I'm not so sure.
Hi,
i also bought some 10uF miniature Elkos and use them in a Tubescreamer Clone.
The Sound ist good to my ears. Im not sure, if the normal Oilcans will
make a better sound... i think there is no difference, and if there is one,
you will not heat it, when playing your Songs with your Band, or on Stage.
bye
Oliver
Only dead Fishes go with the flow... >-))))-°>
Hal
i think the smaller ones are generally lower voltage and higher tolearance...But yea, should be good.
