Mxr MICRO-Flanger schematic?
Started by anticpunk, January 16, 2004, 10:46:41 AM
anticpunk
Hello all,
I've had the micro-flanger for awhile and it's been dead for almost as long. Never loan any of your vintage effects to an idiot. So, does anyone have a suggestion as to where i could get the diagram? I really just need to know where the wires to the pots and jack go......... the board is ok but a bunch of wires got pulled off. It's dc powered and has only 2 knobs...
thanks,
Jason
I have one of the black plastic box Commande series flangers by MXR.  It seems to be similar to the Micro Flanger in a few ways.  First, it uses an SAD512D chip.  Second, it also has only a Regen and Rate control.  Maybe there is enough similarity to figure things out.
smoguzbenjamin
What the hell happened to it???
anticpunk
hello,
Mine also has only rate and regen. controls. Perhaps you could give me the pinout for the pot connections? As i recall it has lettered pads that the wire connect to.
As for what happened..... He said he just changed the battery. Right.
Looked like he thought the battery was under the board, obviously ignoring the rectangle marked 9V toward the lower portion of the case.
thanks,
Jay
vdm
hey mate,
if you post a pic of the front and back of the board, i can probably figure out the schematic for you.
trent
anticpunk
Thanks, I'd really appreciate it.....  have to get the digi camera back, then i'll post them.
Thanks again,
Jay
smoguzbenjamin
Lesson learnt: don't lend your FX to anyone. I don't :roll: ;)
Boofhead
anticpunk, if you want this traced it's no problem, but you have to get pics of both the component side and the copper side of the pcb, and also a shot of the pots and connectors.
