where's the pcb photo paper link
Started by troubledtom, January 18, 2004, 12:18:10 PM
troubledtom
i can't seem to find the thread.
         thanx,
             - tom
Joep
Hi Tom,
There is one here too:
http://www.geocities.com/thetonegod/etch/etch.html
It uses transparent sheets. Imade some PCB's this way lately and they turned out to be the best so far.
Bye,
Joep
troubledtom
thanx, joeb!
   that's the one i was really looking for. tyoe and brand of sheets did you
use?
       very cool, tone god.
                  - tom pollock
troubledtom
opps , i mean..........what type and brand did you use ?
Nasse
I think some people have reported "glossy" one works best, dunno about differences between manufacturers...
Bill_F
Quote from: troubledtomopps , i mean..........what type and brand did you use ?
I've used Kodak Ultra Glossy with good results.
Joep
Hi Tom,
I used 3M transparent sheets for this. I found some leftovers at work, I'll check the exact type for you.
It works really nice, but there is a bit of practice involved. I used an iron on the "coton" temprature (this is not the hottest, hottest will melt the sheets)
Try to heat it as equally as possible. After some time the traces start to "smear" a bit. Stop immediately, let it cool down, and the sheet will come of easily. Touch up with an etch resistant pen and voila!
Bye,
Joep
troubledtom
cool joep!
   thank you very much :wink: did you use an inkjet or laser printer?
            peace,
                - tom
Joep
You definately need a laser printer. This one uses toner that will still on the board after you iron it.
Bye,
Joep
MarkB
Tom - this is the tutorial that I went by.. worked perfectly.
http://www.5bears.com/pcb.htm
The Tone God
Quote from: troubledtomvery cool, tone god. - tom pollock
Thanks! :)
Andrew
